making a door
making a door
making a door
eliot feldman
I don't recall seeing many posts on making a door. Are there some good sites where plans are available? I'm thinking about a big project -- a double patio door with a large glass insert. You wouldn't believe the price quotes I've been getting from the door companies!
Re: making a door
Re: making a door
Dick Coers
Have you priced glass and hardware? You might change your mind. If you still want to do it; choose a stable, rot resistant wood, preferable rift or quarter sawn for stability, motise and tenon, epoxy, flexible caulking to bed the glass, silicone bead weatherstripping, the list goes on. You may choose to use engineered rails and styles to try and limit twisting and warping. Exterior doors aren't easy, hence the price.
Re: making a door
Re: making a door
John in NM
There was an article on it in one of the older FWW books - the color picture one on traditional techniques if I remember right. If you have the CD it will be in there somewhere too, it was early on but after they switched to color photos.
The article is about building a very traditional raised panel door, but it does give you insight into techniques that apply to any door you wish to tackle.
I've built a couple, and they are tough but not impossible. If I do a couple more, I might get up to the level of competent with them :D
As Dick suggests, get all your hardware and weather strip stuff before you start. I like some weather strip I buy from Home Depot, once when making windows I got a big box of it from a place in Georgia for half the price. For one door it's easiest just to go buy three pieces. Stuff jams into a saw kerf, easy to do.
Re: making a door
Re: making a door
George Koch
I don't know where you are located but most area require insulated (dual) and tempered glass in exterior doors.
Re: making a door
Re: making a door
Bill Howatt
I second that quality materials are essential. You want everything to remain true - the alternative spelling for "warping" is "binding".
Bill
Re: making a door
Ditto what Dick said
Hi Eliot,
Unless time means nothing to you, you're better off leaving door construction to the manufacturers. Having made numerous custom entryway doors, with and without sidelights, over the years, I can attest to the scope of work. To make the doors themselves, you'll need a way to do heavy mortise and tenon joinery. Then, you need to purchase and install the thermopanes and mortise for a French door entry set. Add in a weatherproof finish, a jambset, weatherstripping, and large ball-bearing hinges, and you've got a pretty hefty investment just in materials. Figure in your time and you may want to spend the money and keep your time for other ventures.
Just a hunch.
Re: making a door
Re: making a door...Alternative
If you are not really pressed you might try buying the components and re-purposing them.
Check in the back of Home Depot and Lowe's and they often have damaged units they sell cheap(er). I would assume other lumber yards and borgs have similar sales.
Also, a friend attends freight auctions monthly and there are often doors there. Sometimes there are individual doors and sometimes entire units with frames and sidelights. Sometimes there are a few and sometimes many. He does not usually buy them because he has no use for them personally and they are bulky and somewhat difficult to sell. They are there for a reason. Some are smashed badly but many are only slightly damaged. Often the frames are slightly damaged, broken brick molding or whatever. With your wood working skills some would be easily repaired. I have seen units sell for about 10% of retail.
Also, I agree with all those who have been advising you to not try making a door. I made a few and it was not worth it and much more difficult and expensive than it would appear on a one off basis.
Re: making a door
Snooker around
When I rebuilt my shop 15 years ago, I needed entry doors and windows. Buying them new would have cost me a fortune, so I checked into local secondhand stores and found 12 brand new Marvin double-hung wood windows for $100 each and a double-door entry door, slightly used and pre-hung, with a Baldwin mortise lock and trim, for $150. Granted, that was a pretty special deal, but the point is that often builders or homeowners will special-order things that they find out later they can't use for whatever reason, and they'll consign it to somebody who deals in that kind of stuff. Craigslist is another option, and if you look in surrounding areas as well, you improve your chances of finding something, but you need to be systematic and determined and have a loose time frame.
Good luck.
Re: making a door
maybe NOT making a door
eliot feldman
Two double doors for me means four doors, and after reading all your thoughtful posts --especially the one from Ellis, I think I just may forgo this effort. My wife, too, says (kindly) that while she knows I could do it eventually, she doesn't want to wait that many years!
Re: making a door
Re: Snooker around
Had to smile Ellis, cause I did the same thing when I built my shop!
There is a business near here that sells flooring, windows, doors and other items that are obviously purchased from manufacturer's ~ somewhat odd sizes, limited quantities etc. When I purchased my windows and doors for my shop, I visited them and basically stated that I wanted a "deal" on windows and doors they wanted to move. Found 5 double thermopane windows of pretty good quality (odd size) and a steel pre-hung entry door with thermopane window for less than $500. Size wasn't an issue since I was designing and building the shop myself.
Re: making a door
Re: maybe NOT making a door
Bill Howatt
That perspective was applied to our purchased kitchen cupboards.... I even had bought a couple of books on how to make them but it wasn't moving along too quickly!
Bill
Re: making a door
Probably wise
John in NM
I've built both doors and cabinets for various remodel projects, but never while trying to work a 5 day a week job - I can't imagine how hard that would be to do. Every time we've done this, I've either been between jobs or working my current schedule - 7 days on and 7 days off.
