Grizzly G0715P "road test"
Bought the Grizzly G0715P table saw for the Playhouse.
Bought the Shopfox D0257A mobile base also.
Total price was $970 delivered. Delivered by a UPS Freight contractor. The truck had a lift gate, though it wasn't necessary as we have a loading dock at the playhouse. It cost me an additional $245 for a 220V circuit.
Three cartons for the saw. There was minor damage to the cabinet box (some people shouldn't drive forklifts). All contents were in good shape.
It took a few applications of mineral spirits and paper towels to remove all of the shipping "cosmoline" from the table and the extensions. After the removal, I waxed the table and the extensions.
I removed the existing grease from the trunions and moving parts and applied more grease.
By that time, my help had arrived. Put the door on. We fastened the extension wings on the top relatively quickly. I had to lower the motor and swing the door out of the way to fasten the left wing. It was no problem leveling the wings.
Installed the front and back rails. Installed the front tube for the fence. Put on the fence. Put on the factory blade. Note - there is a push lock for the arbor. You only need a single wrench to install the blade. Checked parallelism between the miter slot and the blade. Within 0.002 across the length of the blade.
Installed the blade guard. Wow - this is easy. It slides on quite easily and removes quite easily. It also comes with a riving knife. I am favorably impressed by the ease of removing either.
The saw comes with a 6-20P 220V plug. I made an extension cord so that I could position the saw where desired.
Ran some test cuts with 2 x 4s and other 2 x lumber (rips and crosscuts). Nice. Really nice. Even with the factory blade, it cut well and easily. Made some test cuts w/ 3/4" plywood. Again, nice.
My general impression - this is a well made saw. It should work well for many years.
Caveats - the miter gauge - it is quite substandard. When I have the funds, this is going away to a garbage can somewhere. The blade wrench - stamped steel - I think there was a contest on how thin they could make it and still do the job. Arbor nut is a bit thin for my taste.
If y'all want pictures. They can be provided.
Would I buy it for my own shop. Hmmm. I have a cabinet saw with which I am quite happy. I do think it is a good saw though.
Re: Grizzly G0715P "road test"
Chuck in Mtl.
Pics are always nice to look at.
Kevin French
I owned a G1023RLWX 10" 5 HP 240V Cabinet Left-Tilting Table Saw and liked it a lot, your saw should do a great job for a lot of years.
Thanks, JL.
Stuart Hough
Good info for when I get ready to upgrade from my Craftsman saw. on another topic, the leaves should be starting to show flame right about now in B-ville. I'll bet they look amazing! I might be visiting mom in a few weeks. I'll call and see if we can get together!
