birch burn marks.
birch burn marks.
birch burn marks.
Jack Putnam
I am having a problem with the speed on my scroll saw. I have a excalibur scroll saw with variable speed. I have the saw going fairly fast and I am cutting birch plywood 1/2 inch thick I have two pieces which is 1 inch thick total and has to be cut at the same time in order for the patterns to match up. The saw blade I am using is a skip tooth fret saw blade #448F, width -.045, thick -.017, TPI - 11.5 It's worse when I use a fine tooth blade.
My question is why am I getting burn marks on the outside of the pattern and also on the inside of the pattern? I am making a floating wine bottle holder and this is the 3rd one that has burn marks on it. Then I have to hand sand to try to get the burn marks out it doesn't get rid of them altogether but it looks a little better.
Now can somebody tell me what I am doing wrong. Appreciate any help at this time. Thanks a lot.
Re: birch burn marks.
Ron in Sterling CT
Try putting some clear packing tape on top of the pattern to act as a lubricant.
Ron
del schisler
i use this blade for thick wood , seam's to work ok , it is a number 7 and i use a number 5 also , i have other's but these seem to work best for me, i guess you could match up the teeth on other blades and see how it work's, the reason for the reverse teeth are for a cleaner cut on the botton and the ease of the cut, call mike and talk to him . these blade are from mike wolf work shop, i only use these and not box store stuff , i have the hagner 18V and i run it full on speed good luck here is the link https://www.mikesworkshop.com/blades.htm call mike and talk to him ,
FD-UR No. 7
5 length
0.043 width of blade
0.017 thickness of blade
12 tpi
Every 3rd reverse tooth
FD-SR No. 7
5 length
0.017 thinkness of blade
10 tpi
7 reverse tooth
William Duffield
…or lard paper (traditionally used in Boulle work) or even wax paper.
Frank Orfanello
I too have used Mike's blades and find them to be the best I've ever used.
You can't go wrong with these.
