Have a question? Ask Woody!
need info
need info
need info
Joe Mohnike
What can anyone tell me about Watco lacquer. I would like to know if it can be sprayed. If so what PSI do you use and what size of tip. I purchased a quart of it to experiment with and have brushed it on, so far so good. I have used varnish, and urathane in the past, but they keep changing it and it is to the point I can not find a product that I am satisfied with, (thanks EPA). Also how well does it hold up and would you recommend it for table tops. Any information will be appreciated.
Re: need info
Re: need info
mdclor
Joe, this won't answer your question directly but it may be helpful for future reference.
I spray Target Coatings EM6000 which is a production lacquer with a 1.2 tip IIRC. It lays down really well and requires little to no light hand sanding between coats. I add CL100, a cross linker, for table tops and it has been bulletproof for my applications. You can also add a dye (I use TransTint) to it if needed.
There are other waterborne lacquers, but I have only used the EM6000. FWIW
Re: need info
Re: need info
don stephan
General Finishes also makes very good water borne finishes if you would consider non-solvent. I used to spray their EnduroVar and it warmed the wood a surprising amount. not sure if that particular product is still made.
Don Stephan
Re: need info
Re: need info
Joe Mohnike
The Watco product is solvent based, not water. Sorry I should have mentioned it earlier.
