stain splotches
stain splotches
stain splotches
Jack Putnam
Well I'm back again. Thanks to all who gave me suggestions on how to eliminate wood tear outs. Now I have another problem. After I finished cutting out my pattern on the birch plywood I brush on a wood conditioner wait abut 10 minutes then wipe it off. I do this after I sand the wood down. Now when I apply the stain to the wood, I wipe it on then about 15 seconds I take a rag and wipe it off.
MY question is why do I still get splotches on the wood after I stained it. It looks awful and in some areas it looks real good. I thought maybe the wood conditioner would have taken care of that. Thanks again for any help you can give me.
Re: stain splotches
More info needed
Dick Coers
Can you get more specific with type and brand of stain? Water or solvent based? Dye, stain, or combination. What brand of stain conditioner? How fine of grit with sanding?
Re: stain splotches
Re: More info needed
Jack Putnam
This message is for Dick Coers the type of stain is Minwax Wood finish, red mahogany solvent stain. I used Minwax-prestain wood conditioner. sanding grit is 220.
Re: stain splotches
One solution
Lee Schierer in McKean, PA
Birch is notorious for splotching. What you can do is apply MinWax Pre-stain conditioner and it will reduce the blotching to a large extent. The blocthing occurs where the grain turns up toward more end grain in the wood and it absorbs more of the stain than the face grain that is elsewhere. You can also try sanding only to 150 or 180 grit instead of 220 or higher to reduce the effect.
Maple will do the same thing.
Lee
Re: stain splotches
Dick Coers
Thought so. The products you bought are not known for working well. Their stain controller is basically thin oil, and maybe a little varnish. No way that will dry in the open cells in 10 minutes to keep out their thin dye/pigment stain from soaking in. A shellac wash and glaze works well. NGR or gell stain works better than Minwax. As I always suggest, never experiment with unknown product on your finished work. Always experiment on scrap!
Re: stain splotches
He said he used that already.
Re: stain splotches
Richard McComas
Spend sometime on the net and research "Charles Neal's Pre-Color Conditioner - Blotch Contol".
I haven't use it myself but all I hear/read about it is very good.
Re: stain splotches
It works
David Yoho
I've used it in a few situations and it does the job as advertised. I know Charles personally and he wouldn't put something out there unless it did what it said.
On the other hand, I think the original poster could have avoided the blotching issue had he used a different stain or prep and not spent the extra money on the blotch control product Charles sells. Don't get me wrong, the product works, but I think it's overkill for something this simple. A gel stain or a pre-seal of thin shellac would work just as well.
Re: stain splotches
charles neil  blotch control the best
del schisler
i use it when i am building lagrer item's , it works i have used it for yrs . this blotch control you brush it on and let dry, you dont rub off dry, this dry in a short time , depends what temp. you have, the link http://www.youtube.com/watch?v=IfCYMdrP8rM
Re: stain splotches
Re: stain splotches
ChuckinND
Nowdays the veneer of the plywood can be pretty thin. Is it possible that you sanded it too much, and now your dealing with spots in the veneer that is glue soaked ? I've seen it happen with new doors if they get sanded too much.
Re: stain splotches
don't overlook another factor-sanding
Sanding. Before staining the surface should be sanded to 180 or 220 until there surface looks uniform in luster. Any dull areas indicate areas where sanding dust is collecting and if the grain is rough enough to collect dust it will capture stain particles as well. However, some of the Chinese birch has veneer so thin that one might risk sanding through with coarser grits, even with hand sanding.
Birch plywood is hard to stain uniformly. I have never been successful but then I never tried the well thought of Charles' blotch control.
