Stereo Speaker Repair Suggestions
Bart Goldberg
Bart Goldberg
I have an old pair of rather rare/unusual stereo speakers/Monitors that need to be repaired. The very bottom of the cabinets has a plywood structure that make up "feet/base" of the cabinet. The plywood is coming apart and delaminating. I am trying to decide if I should replace with new plywood, or use hardwood instead. Any advice?
Thanks
Bart
Re: Stereo Speaker Repair Suggestions
John McGaw
If the speakers are indeed rare/unusual then restoring them as close to the original state would seem to be in order. I'd suspect that delaminating plywood would have been caused by low-grade plywood in contact with moisture. Concrete floor? Flood?
Bart Goldberg
Bart Goldberg
John, your absolutely correct. These speakers had been stored away in an old damp basement in Brooklyn for over 20 years. I've already fixed the electrical issues, but the bases needs to be rebuilt.
If you're not going to repair the existing plywood
Howard in Toronto
But if you're going to make new cabinets, I'd think MDF is your best route.
Its density should minimize unintended resonances in the cabinet solid wood might put into motion. Just study the existing boxes as you take them apart for baffles and vibration management etc.
Howard
Ply is very different, acoustically, from solid hardwood. I would stay with the ply but note that you won't find plywood to fit since 3/4" became 16.5mm in the interim
Bart Goldberg
Bart Goldberg
Just to be clear - the cabinets are intact and I'm not planning to replace them. They are, in fact, Art Deco style cabinets, which makes them so unusual. Its the plywood that is mounted under the main cabinets, that are like a short pedestal that I'm having to repair. Therefore, I dont think there are any issues wrt acoustical impacts.
Thanks
Bart
