Help with missing part
Don Orr
Knowing the braintrust here is extensive I have a request to help me find a missing adapter for the forstner bits pictured below. I got them in a box lot of various drill bits and accessories at an auction. The bit sizes are in imperial units, marked Germany and HSS. They are very sharp!.The threaded holder that the bits screw into is missing and I would like to see if I can find one. It would have been in the empty spot at the bottom of the box. I treid to measure the threads and came up with are either 5/16 x 20 tpi or 8mm x 1.25. Neither exactly fits my thread gauges but bith are very close. I am confused because the bits are made in Germany but the sizes are imperial.
Thanks in advance for any help.
Re: Help with missing part
John Veerkamp
Take the bits to a hardware store. Most have both male and female sizers for metric and English threads.
Hank Knight
Or, take them to your local machine shop. They can fabricate the adapter for you for not a whole lot of money.
Second the machine shop
Gary Smyth
These look as if they may be made for an automated machine. A machine shop will be able to provide you the thread precisely, and be able to cut inside threads for an adapter to fit the bits. They may also be able to tell you who made them and you then could contact the manufacturer for the absent part.
Any chance of you going back to the auction seller and asking if the missing part was found? Long shot, but worth a phone call.
Tony - Memphis
I have the exact same set. I bought it at Sears when I first started woodworking back around '96. I'l try and remember to get a pic and measure the threads tonight.
Tony
I betcha...
John in NM
The thread is 8mm 1.25, because 5/16-20 is a really weird old pitch, and they are from Germany :D
From what I've read the two are just about interchangeable.
Dick Coers
Try Southeast Tool. They sell threaded shank bits with m8x1.25 threads. Couldn't quickly find an adapter, but looks like a good place to start.
Thanks for helpful hints & suggestions !
Tony - Memphis
Well, wouldn't you know...I just threw the original box away a few weeks ago. Anyway, here are a couple of pics. I didn't have anything to measure the treads with. At least you can see what the original shank (or whatever) looked like. I'm guessing it would be quite expensive to have one made!
Sorry for the fuzzy..I used no flash and then had to shrink...
Thanks Tony!
