Spice Box - 3. The stopped dadoes for drawers
Routing the drawer divider dadoes
First a couple of guiding principles. One should do high risk operations before high labor low risk operations. To that end it would have been less risky to cut these dadoes before dovetailing. Second, if one does not do something often enough to become nearly risk free, build in numerous checks to lessen chances of mistakes.
I don’t use a router much and only recently acquired a router table. I never could bring myself to pay the price of a table saw for one of these things, but then I found one used. Hence, my router skills and experience are not high. When I asked how to make these dadoes I received many suggestions any of which would have been reliable and precise to implement. The question became which would be easiest to employ.
PIC 1
I decided to use the router table. The fence ensured that the dado for each side of the case would be precisely located from the reference bottom of the case. The requirement is essential to result in straightforward drawer fitting. However, I did need to make sure the bottom was accurately square to the sides. A stop block ensured that the dadoes stopped in the correct place.
The dadoes were cut with a 1/4" solid carbide bit. If you have not used solid carbide bits, do try them. They are sharper and stay sharper much longer than brazed bits. The sharp bit resulted in almost no detectable force on the piece that could have thrown it out of proper registration on the fence.
PIC 2
I discovered a feature on the router table I had not previously discovered. There is an adjustable scale on each end of the fence. Once I set it for the first dado I could quickly reset the fence for the others using the drawer spacing measurement from my drawing.
Based on past experience I knew that it was quite possible to get something misoriented or in the wrong location when working on mirror image parts. I used the following crutches to avoid these disasters. First, with chalk I marked the rough location of each dado. Sure enough this crutch kept me from cutting the wrong side on the first dado.
PIC3
Using one of the cut-offs from making the sides I marked the dado locations. I used this piece after each fence setting to test cut location. Indeed, this crutch kept me from cutting one dado off by the thickness of a divider.
PIC 4
And finally I can’t have too many marks to indicated side orientation, front and top.
Re: Spice Box - 3. The stopped dadoes for drawers
Adam of Oakland
Adam of Oakland
Hi Mr. Tindall - YES, 'specially when those high risk ops involve the unforgiving bit of a spinning router :-).
I had to reread and parse your initial sentence. I'm assuming you would have been happier milling the dados before putting all the time into the dovetails, ya?
We can commiserate to some extent today as I made the same mistake with my project. I got these slip-joints of a jewelry box lid frame dialed in *perfectly* from the band saw in the AM, but it was done before routing grooves for the panel. luckily only a little CyA glue was required to repair the blow out in my tennons.
Interesting to hear you're new to router table stuff. Me too. I improvised one on Friday out of plywood. So far, only one cut that went pear-shaped due to pilot error. It is an unfriendly machine, for sure. not like my plow plane.
Thanks for posting your photos, it's always cool watching what you're doing.
Agree with Adam
Joe in a Cleveland suburb
When he wrote:
"Thanks for posting your photos, it's always cool watching what you're doing."
Looking forward to the progress pictures.
