200+ woodworking book reviews
Question-How to make stopped dado?
The dividers for these drawers are 1/4" panels that slip into stopped dadoes. To get the drawer opening to be near square, and hence easy to fit, these dadoes must be exactly equally spaced on both sides of the case. The question is how to make these stopped dadoes to ensure that they are equivalently spaced on each side of the case side?
Re: Question-How to make stopped dado?
Router + Moveable  Fence
Can also do it on a router table with a fence. Can do with a straight bit or, for extra strength, make a stopped sliding dovetail.
BTW, for this cut I prefer a square router base to eliminate any "centering error".
I usually cut the dado and then just move it to where it was supposed to be :)
Seriously, how about going at it backwards. Cut the dado first, then trim the ends of the board.
How are you cutting them, by hand, router, what?
With a router you could make a guide/template and line it up carefully. I make them fit the base of the router. Either my router is lined up really well with the bit centered, or I am too blind to see the error. (I never have figured how a thousandth or two mattered in wood working.)
Ps....
Mark and I were typing at the same time and I was not referencing his comments about centering error. OTOH, I have trouble with square based routers because if you do not keep the edge tightly to the guide and you allow it to pivot, you WILL have error. With a round base, if you rotate the router and the bit is badly centered, you get error, but if the bit is centered or nearly so, you won't. I use guides that have a fence on both sides to the router cannot wander. It would work just as well or better with a square based router. Either way, trash is your enemy between the router and the fence.
I also cut both pieces at the same time by putting the edges together, lining the pieces up, plunging the router, and stopping at both ends. Book matched as it were.
Gary Smyth
Is it possible to make a full size art board template/story board? Make the more flexible art board to fit the right and left sides of the spice cabinet sides precisely. I would think that some settable spring dividers and an exacto knife would get you the spacing you need within the width of the point. You do fussing with the drafting tools and not measuring except as estimated distances. In tight spots I layout what I want full size on art board and when satisfactory, register it to the board and place on top of the wood and at important spots as marked on the paper board template use a compass point/drafting scribe to punch through the paper board to accurately mark the wood underneath. Once that is done you can cut thin wood to size and with tool spacing to act as a guide/fence/stop for the router, or plane. scraper/chisel.
Since this is for multiple spice cabinets of identical dimensions, once it is laid out for one you will not have to make the templates and guides again. As long as the sides are identical size the template marks (and wood marks underneath) will all be the same. In my experience the accuracy is very good.
David Yoho
If I read you right and the part with the dovetails is one side of two and they're for spice cabinets, therefor small, I would use a router and cut each dado in both pieces at once. I use a shop-made guide template with my router to cut a number of different sized dadoes, which means I have a number of guides made up.
I would clamp the sides face up, rear edge to rear edge, locate where the dadoes need to be, set my gude to the line, and cut the stopped dadoes. This insures both interior sides will be mirror images, so to speak.
Matthew Robinette Mt Juliet Tn
Hey I think in Tage Fried's book 1 chapter 7 pg 144 he has provided a good picture of a sliding stopped dovetail that from my guestamation is about the same thing as a dado exercise.It seems to old coot could do a lot of things that seem to me to be made without a lot of fuss.
Stephen Kirk
This is how we did it when I made a spice box during a class. Once you know the offset from the base to the edge of the bit it's easy to make a spacer so you can accurately clamp down the fence. Pretty fast and simple.
Question
What does you guide look like?
Router Guide
David Yoho
I got the idea for mine from Glen Huey. They are simply 1/2" MDF on a piece of tempered hardboard with a piece of 1/2" plywood for a cleat below.
Here's one of the guides laying on my bench -
Here's the bottom side -
Why didn't I think of that!
Now that is simple, elegantly so. Thankyou
PS
What is the secret for keeping your bench uncluttered? I need this tip.
That's what I was trying to describe...sort of
Bill, the one I tried to describe above is sort of a double version of that. One on the left and one on the right and the router slides back and forth between. That way the router can not escape and wander off on you and a piece of trash in the tracks will tend to stop the router rather than cause it to ride around it. And you can install stops front and rear where ever you need them. Also, you can make the guide piece on the bottom longer to more accurately square the work piece.
The one in the picture is a very quick and easy thing to make and very useful. You just attach the top piece to the bottom piece and use the router and the exact bit you want to trim the edge of the bottom piece. Then you can lay the guide on the work piece and the edge of the groove will be right where the edge of the guide is.
Speaking of routers and jewelry boxes....I made one a few years ago where I wanted about twenty round bottom depressions sort of like and egg carton. They were for ear rings. I have an 1 1/2" core box bit and a plunge router. I tried making a plunge, but the route was too powerful and made a mess of the hole. I made a rectangular frame on a piece of 1/4" plywood. On the bottom side, there was a frame that retrained the work piece. On top the frame was larger to account for the router base. I made a series of strips of wood that filler the top frame leaving just the space for the router. It was like kids blocks or a simple jigsaw puzzle. Plunge one hole, move the filler piece around to shift the router down the row, plunge the second hole, etc. More complicated to explain that to do. Worked very well and she was thrilled with the end result. One minor problem was the core box bit tended to burn the sidewall of the holes. I think some bits do and some don't, and they can be reground to eliminate it, but I am not trying that. I use the Dremmel with one f the "scotchbrite" heads on it to sand them clean in seconds.
The router is sort of like the lathe. For such a simple tool its astounding what you can get out of it.
No secret really
David Yoho
My method of work is a bit unorthodox I suppose. My free standing bench (in the pictures) does double duty. It acts as an out-feed table for my tablesaw, as well as where I do all my joinery work and assembly. It has no vices, dog holes, or tool tray but is built heavy enough to take the pounding when cutting mortises or not dance around when planing or using a cabinet scraper. I also have an attached bench along one wall that is behind me when I'm at the one pictured. When clutter happens, it occurs there.
Ditto
also . . . .
