Double Sided Tape
Double Sided Tape
Double Sided Tape
don stephan
From time to time I use double sided tape, usually to secure a router template to stock. Finally used the last of the roll Monday and a search of several local stores, including Homey Domey, didn't find much. Carpet tape looks like it would be a bear to remove after routing - very open weave that may shred while trying to pull it up.
I've seen "turner's tape" in a woodturning catalog, but the closest woodworking store is 45 minute drive each way.
Wondering what others use, besides brads/pins, to hold router templates in place temporarily.
Re: Double Sided Tape
Terry in Edmonton
Carpet tape is quite useful in the shop, but can be a bear to get off. I find other types of double sided tape at office supply stores and craft stores. The big box craft stores usually have several types and grades of tape that find use in my shop.
Re: Double Sided Tape *LINK*
Lee Schierer in McKean, PA
Here's a link to a source for double sided tape.
Double sided tape
Depending on how large the parts are,
Keith Newton
You can use vacuum to pull them together. I think you can find and article by me in the archives, where I was using just a shop van coming up through a work table to hold some 3From plastic to a template. This is only good for about 1 psi, but you can use better vacuum pumps for higher numbers.
Besides using the vacuum, I sprayed the face of the template with a coat of contact, then let it dry, to give that face some tacky friction, but you could also have some sharp tacks sticking up as well.
The neat thing about using vacuum, is that you just turn it off to release the part. See if you can find the article, and if you have any question, I'll be happy to answer, if you will give me something / information to work with.
Yonak
Double-sided tape ? Oh, you mean "Supervisor Tape", as a former fellow employee of mine was keen to say.
I've heard some people use dabs of hot melt glue. I've never had occasion to try it but I thought I'd pass along what I'd heard.
For paper templates I use spray adhesive.
Acetone is your friend. After peeling off most of the carpet tape, I have used acetone and a green abrasive pad to get the remnants.
Uline
paul woolson
do yourself a favor and buy some Uline brand double sided paper tape. It's masking tape so it's very thin. Yet holds stuff better than any carpet tape I've used and doesn't leave the "yuck" behind.
I wish I knew about it 10 years ago.
http://www.uline.com/BL_3117/Uline-Double-Sided-Masking-Tape?keywords=Double-sided%20Tapes
William Duffield
If you decide to stick with double sided tape, you can get it mail order from Woodcraft and several other vendors. Not everybody gives it the same name. I have experience with the Woodcraft products. They carry double sided tape and double faced tape. Their "double sided tape" is much stronger than big box carpet tape. I think you will find it sufficient for router templates, as long as both surfaces are smooth, flat and clean. Their "double faced tape" which I think others call "turners tape," is incredibly strong stuff, much stronger than you would need for any woodworking application other than sticking turning blanks to face plates. You need a solvent to get it off.
You didn't describe your application. If you need to go all the way around the object (e.g., cutting boards, etc.) then tape or Keith's vacuum method are probably your best bet, but if you are building components for architecture or furniture where some faces of the component will remain unrouted (e.g., for joinery to other components), then I find Bessey Auto-Adjust toggle clamps either much more efficient or more secure, since unlike double sided tape they attach and detach almost instantaneously, and no extra steps for tape backing paper removal and adhesive removal are needed.
I don't have any experience with the vacuum systems. Other than initial set up complications and cost, including a compressor and a Venturi or a vacuum pump, and the minor convenience of vacuum hoses getting in your way, they should work well.
Toggle clamps do require construction of more complicated jigs than tape, and the simplest ones require use of a top bearing template bit, whereas you can use a bottom bearing bit for taped and vacuum templates. Bottom bearing bits are usually more robust than top bearing bits, and less expensive, and you can choose ones that can follow tighter radii.
You can devise templates that work with toggle clamps and bottom bearing bits, but they are more complicated. They can be worth the effort if you are making enough identical parts. (I prefer Bessey Auto-Adjust toggle clamps, but they are a lot more expensive than Chinese knock-offs of De-Sta-Co clamps.) Illustrations of these are not easy to find. This jig, by Steve Latta in FWW, uses a floating template, and the clamps hold both the template and the stock against the carrier. If you want a template that is fixed to the carrier, then you need to drill a couple of holes through it so the toggle clamps will pass through the template and directly engage the stock. Although I don't believe this technique is unknown, I can't find any examples of it on the web.
Menards
Jerry Gibbs
Class instructor recommended Menard's indoor/outdoor carpet tape. For me, the biggest issue is holding power, not removal.
Matthew Robinette Mt Juliet Tn
I use a bit of the sticky stuff from time to time at work and your best bet would be to go to Grainger or MSC the available double sided adhesives is wide and deep. I think going to the big box in stock inventory hasn't proven to me to anything but frustrating because of the limited stock on hand.
OMG I love double sided tape!
James Heaston
Its like a rare earth magnet for stuff that ain't steel.
Yeah it's hard to remove, but I wouldn't want it any other way.
I use it for soooo many different things. Set up blocks, stops, here hold this a minute, etc. Even fake buggers just roll a small piece between your fingers & stick it under your nose. Grandkids love 'em. Tell 'em not to confuse it w/ the real ones; they don't taste the same. LOL!
