Anyone have issues with Triton routers
Stephen Kirk
The above table adjuster and micro winder on my TRC001 started really grinding and got hard to move. Anyone experienced anything like this? I have a question into Triton as well.
Stephen Kirk
Shot-In-The-Dark
Since I've had similar issues with my table-mounted router(Ryobi 3hp) I'll relate that the problem was caused by wood dust clogging up the guide posts. Took it out. Field-stripped and cleaned. Worked smoothly again.
Re: Shot-In-The-Dark
Jim DeLaney, Austintown, Ohio
Sounds likely. I've had similar problems with my Router-Raizer equipped Hitachi M12V. I have to clean the gunk (technical term
) out of it every few months or so.
Re: Anyone have issues with Triton routers
Stephen Kirk
So I got the router apart and cleaned it up. The worm gear had a bit of dust, but it wasn't bad. The problem seemed to be that a shoulder on the worm gear shaft which rubs on a washer where it exits the plastic housing is starting to bind. I put a bit of lube on it, reassembled and now it's working well again. I'll just keep an eye on it. I used a bit of Slipit, but if I get some dry lube later I can out that on instead. I made sure there wasn't any other residue to capture dust.
