I'm thinking of upgrading from my bench top drill press to a floor standing one. I was thinking somewhere in the 5-600 dollar range. I don't need the best just one that is well built and accurate for one in that price range of course.
I agree with Bill. I have a forty year old floor model drill press. I would like to have a table that was easy to raise and lower. A large table would be nice, perhaps with a fence and some hold down devices. An attachable supplementary table would be easy to make. Like Bill I rarely if ever change the speed. I do use mine with an attachment to make mortises. Works very well. Mine has a six inch stroke and I like that. Once in a while the fact that it is a floor model pays off.
Two features that I've found important depending on what you are doing: Slow speed is important if you sometimes drill plastics, steel or other metals; quill travel distance is important if you drill a wide range of material thicknesses...or need to drill deeper on an assembly where additional quill travel allows you to clear obstructions. Both are considerations, not necessities. There are always work arounds which involve more process time.
Keep in mind that drill presses are potentially really dangerous, be sure to get a vise for it. Keep in mind that your new model may be (depends on the size of your table top) a lot more powerful, and they can do terrible damage. I also run mine low most of the time, but they are unstopable with a 1/2 horse motor and geared down.
Variablle speed (electronic, can be had for very little), and a hand tightening chuck or one to fit into the main chuck, are convenient.
I've been bitten more often by my drill press than any other tool. Easy to get complacent. One of the easiest ways to avoid this is to have a fence on the drill press - even just a chunk of 8/4 that is clamped down where needed.
Depends on what you use it for. I do change speeds now and then, since it helps drill straight holes if they are deep - but bear in mind, I'm talking about 4" or more deep.
I also use the table vertically a lot (deep holes again ), that is unusual enough that few of the Chinese machines tilt past 45 degrees. The 17" Jet we have at work does, but those ones with the funny little round table don't.
Table raising mechanism is always nice - but the one at work has a shop made crank. I'm guessing the cast cranks break easily. Probably not a problem if it's just you in the shop, we have a number of engineers who forget to release things like the table lock before cranking away.
Then the big one that I like is a spindle depth lock. I do a lot of stopped holes, so it's handy to be able to lock the spindle depth at the start of a hole and then set the depth stop relative to that. My old Rockwell has a lever to do it, which is more convenient than the third nut below the depth stop method (again, that Jet at work does it that way).
I'd just be using it for woodworking projects and maybe some light metal drilling. I was thinking 500 or so would weed out the shoddy ones. I'll more than likely add an aftermarket table and fence to it. The reviews I've seen on the ones I looked at are good on one site but go to another and they become less favorable. It would be nice if all Internet retailers that have reviews would use the "verified buyer" designation, if that can even be trusted in this digital day and age.
I run mine with a foot switch. If something happens I can just lift my foot while keeping both hands on the whatever.
Speaking of foot switches, I think they are a must for drill press and router table. Don't forget to enclose the switch so that it is not inadvertently stepped on and activated.
I like everything about the Delta I bought at Lowes. Large Table, good light, easy depth adjustment, easy table height adjustment. If there is something to not like I have not found it in 4 years.
Oh, one other thing. The table is easy to fasten stuff too.....unlike the older model I relegated for mortising.
Where I always run into trouble is doing things like a 3/4 hole with a 1 1/4" Forstner. There is just no hanging on to that when it grabs (full holes are much less likely to grab, since the bit is fully surrounded).
The nastiest one was a 1/2" piece of aluminum with a burr on the end. Twist drill grabbed that as the bit went through the last little edge of metal and spun the piece right out of my restraining grip, giving me a nice gash on the wrist. Had it been steel and the burr a bit sharper, that would have been a ride in the ambulance.
While a foot switch is a great thing, and a must if one has long hair I still think the fence is more important. Keeps the work from getting out of control if you don't have the work clamped down.
A drill press table is easy to make and when I make one with scrap plywood, I feel no regrets screwing down fixtures, etc.
Having said that, I got a store bought table from Rockler a few years ago and really like it. A good table and a good fence thats easy to adjust and attach clamps and stuff to with t-track slots. Its also got a dust collection port with variable sized mouth (including zero). Easy on and off for when I go to a vise or other special set-up.
Only complaint is that some of the formica started peeling off this year. No big deal - a little titebond and a clamp made it good as new.
I have a Delta. Its ok, does what I need it to do.
BTW, a floor model is definitely the way to go - much more versatile than a bench top, but the same footprint.
"A tall upright machine useful for suddenly snatching a workpiece out of your hand so that it smacks you in the chest, exposes the outer tendons of your left thumb for easy daylight inspection, and then flings your beer across the room."
I'm a fan of old drill presses. You can find 50 - 60 year old Walker Turners, Buffalos, Rockwells and Deltas on eBay or Craigslist for not a lot of money - well within your price range. Many require little or no rehab, just a little clean up and lube. IMHO, the new machines can't touch these old boys for quality and accuracy. I found this little Buffalo bench top with a new keyless chuck on Craigslist for $150. It required nothing but power.
I bought this 1950s Walker Turner on the Bay also for $150, but I spent a bundle rehabbing it. I should have looked it over before I committed. Nevertheless, it has turned out to be my go-to machine.
I agree; Walker Turners are great machines. My dad had an older model 900 that was a WWII Navy surplus machine. I loved it, but his shop was broken into and it was stolen. When I started looking to replace my floor standing Delta, a WT popped up on eBay nearby at the Savannah River weapons facility in Aiken, SC. I bought it sight unseen, which was a big mistake. When I drove over to pick it up, the Property Disposal Officer delivered it to me in three boxes. It was a total wreck, a basket case in every sense of the word, complete with dirt dauber nests in the motor and belt guard, a rusted through column and large chunks broken out of the table. Undaunted (stupidly), I found walker Turner Serviced Machinery, LLC in Connecticut, a company that specializes in rebuilding Walker Turner and related machines; and Jeff, the owner, and I set about rebuilding my drill press. Many dollars and a lot of work later, the old girl is back in top form with all correct parts, including the motor which Jeff rebuilt for me.
The serial number on my machine indicates that it was built in the early 1950s, which is the time the Savannah River site got up and rolling, producing materials and doing research for our nuclear weapons program. I believe my machine was one of the early pieces of equipment delivered to the site. That history is probably what kept me from pitching my three boxes of parts in the trash.
In any case, it's a wonderful machine. I'm glad to hear you're a fan too.
I used to have a very early asian one, from when they were made in Taiwan, but they still fit the wrenches to the bolts one at a time. It worked really well, but I finally replaced it with a Buffallo forge one that is a floor base one. Like Hank's but enormous. It think it is in good nick, but I don't know because I keep putting off the wiring of the variable speed motor. In the meantime I have a tiny one I bought for 25 dollars to use in a CNC project, that gets all my work, along with my two mills.
The BF drill was in a machinery restoration shop. It ran a 5 hp 3 phase motor, which I have replaced with a tiny motor. I think the machine cost 150 Canadian, which at the time was around 100 US, and the variable motor was 25 dollars.
