Reallllly OT: What kind of spark plug is this?
Kneale Brownson
Kneale Brownson
I figured the folks on WoodCentral represent as wide a spectrum of experiences as any I'm familiar with on the web, so here goes:
This spark plug came out of a six-cylinder Wisconsin engine used in a Cletrac 40. It's missing the ceramic top that would have identification information. You can see the spark tang that grounds to the engine through the threads.
Here's a view of the assembly opened up:
Here's a closeup of what's left of the ceramics:
Re: Reallllly OT: What kind of spark plug is this?
Butch...Mn
Go to Smokstak web site and someone there will more than likely be able to help.http://www.smokstak.com/forum/forumdisplay.php?f=56
James Heaston
Couldn't ya just check one of the other 5 spark plugs in the engine to see what ya need?
Kneale Brownson
Kneale Brownson
They're all broken off like this one.
Re: Reallllly OT:  What kind of spark plug is this *LINK*
John McGaw
Try to find the engine's serial number and then look it up at the link provided. That should get you close enough to be able to ask the support people at Wisconsin about plugs and other parts.
Serial Number Lookup
Kneale Brownson
Kneale Brownson
Unfortunately, the engine serial number plate is missing from the engine.
Mark Nowicki
You just need to know what would have been the length of top insulator. It would have been up to the thickening on the bent wire.
The nose (bottom ) insulator is still intact.
The length of the insulators determines the heat value of the spark plug.
After that, it is just a mater of finding a plug with the same dimensions.
Mark
Basil
I would guess it to be a CHAMPION plug.....similar to old MODEL T plugs or the old plugs found in antique International Farmall and John Deere tractors.
You may have to measure the size of the threads on the bottom end and just get a plug that will fill the hole.
50+ years ago I had some experience with Wisconsin engines and IH dozers that started on gas and ran on diesel fuel and Champion UF-9Y comes to mind.....for some strange reason. Can't even remember what I had for breakfast but some numbers and things from long ago still ramble through my head.
Remember using spark plugs by the brand name of "Blue Crown" I think it was in Wisconsin engines.
Might have to put the guys at "The History Detectives" from PBS on this one.
Chuck in Mtl.
you may want to try this forum to ask your spark plug question...
http://www.mytractorforum.com/
I'm sorta embarrassed…
Rod Peterson—Ormond Beach, FL
…to know any of this, but I apparently have spent waaaay too much time watching old tractor shows on RFD-TV.
Cletrac (Cleveland Tractor Company) was bought by Oliver (Charles CIty, IA) when they were interested in a crawler for their product line. Oliver was eventually purchased by White, who in turn was acquired by AGCO. It's possible they have archival information that could lead you in the right direction.
Kneale Brownson
Kneale Brownson
So I measure from the bottom end of the wire to where it thickens (where the insulator probably ended)?
Kneale Brownson
See, there's lots of stuff here.  No luck yet
Kneale Brownson
But I'm still working on it.
Mark Nowicki
Yes.
BTW the QC visible on the insulator means it was a Champion brand spark plug.
Edit. Did some googling(?) and Q means the length is 17.5mm (I assume the length of the insulator) and C means it is a copper core electrode.
Mark
Mark Nowicki
Never mind the edit for now, it could be something else.
Will do some further digging later.
Sorry
Mark
Re: See, there's lots of stuff here.  No luck yet
Mark Nowicki
Did some more digging and found this guy:
http://www.pittauto.com/default.aspx?page=customer&file=customer/piauel/customerpages/pl_wisconsin.htm&gclid=COTbqoyyqMECFaZj7AodTjwAuQ
I looked through several of the parts manual and it appears that Wisconsin used the Champion D-16-J.
To find equivalents you can try this site:
http://www.sparkplug-crossreference.com/
HTH
Mark
Basil
Champion D-16J is the same plug I used in Caterpillar D-7 & D-8 dozer starting engines.
Kneale Brownson
Kneale Brownson
Those sound very like what's in the engine, Basil. Where do you buy them?
Champion X
iew dallas.net
This is a Champion X Spark Plug used in the Model T Ford.
Auto store.
Basil
I used to get them at the local auto store. Any auto store should be able to order them and get them over night for you.
Re: Champion X Source
iew dallas.net
I buy mine at O'reilly, they have in warehouse. Usually one day delivery. I use in my Model T's.
Re: Champion X Picture
iew
Here is a picture of a new plug.
Kneale Brownson
Kneale Brownson
That looks like it might work. However, also found out Champion W14 has the same threads arrangement, so that's what I'm going with. They're a bit cheaper, I believe.
Thanks to all for the help.
Re: Champion X thread size
iew
The thread is 3/4 pipe.
