THE WOODRAT IS BACK!
handles/knobs for pull-out puzzle pieces
Simon St.Laurent - Dryden, NY
For Christmas, I'm making a tray map puzzle, much like the classic "50-states" puzzles, except that it's towns in my county.
The map puzzles I remember from when I was a kid - the 70s - had little handles on them, basically plastic cylinders sticking from the puzzle pieces. They made it a lot easier to get them out without destroying the puzzle. (I've seen wooden and metal ones too.)
I'm trying to find some for this puzzle, but I'm not finding them. I suspect it's because I'm looking for the wrong term - they aren't quite knobs or handles, but that's the closest category I can see.
Any thoughts?
Thanks!
Re: handles/knobs for pull-out puzzle pieces
John McGaw
If they are just plain cylinders, what would stop you from making your own from plastic or metal or wood by simply slicing up some round stock? Brass with a small diameter would look good and is easy to work with as well as being cheap; I've used it to make custom shelf pins.
John Veerkamp
Go to a hobby store like Joann's or Michael's or Hobby Lobby. Go to the jewelry making section. You'll find a variety of beads , even stud earrings . There should be something that will fill your needs. The puzzels that my kids played with had little plastic beads on a post that were glued into the piece.
Richard McComas
Maybe something like this or look for jewelery box pulls.
http://www.aliexpress.com/store/product/wholesale-500PCS-12mm-Base-Diameter-wooden-knobs-drawer-knobs-dresser-knobs-cupboard-knobs-furniture-knobs-for/418260_1799186930.html
Curt Stivison
Embed A washer in the bottom of the puzzle piece and use a magnet to lift them out.
Curt
John S
Lee Valley, in with their Shaker Pegs, has Tie Pegs. I use them for small feet (shaft cut to desired length), they should also work as knobs.
Thanks, everyone!
Sorry to post and then disappear into travel. I think the tie pegs and the magnets seem like the most fun, but I'll be trying a few things and sharing the results.
Thank you!
Simon
