Spice Box - 1. Face flattening boards
To be clear for this discussion I am referring to getting one face of a board sufficiently flat that after thickness planing the board is flat enough for its intended purpose.
A jointer can be a handy way to accomplish this task. A down side is that face flattening is hard on jointer knives. The grits that accumulate on rough lumber soon dull the knives to where they are less useful for critical edge jointing. Additionally, the board to be flattened may be wider than the jointer. And, twisted boards require some experience to teeter them on the jointer in a way that takes the twist out.
It has taken me many years to realize that for some operations hand tools are more convenient, faster, and all around "better" than a power tool alternative.
PIC 1
A scrub plane can be an alternative to the jointer for the task of face flatening. A scrub plane can be the cheapest Stanley plane you can find on Ebay or a flea market fitted with a blade that is ground with a camber as shown in the picture. The blade does not have to be very accurately ground nor very sharp to function.
PIC 2
Today I was preparing the case sides for two Spice Box jewelry boxes. In some situations flat is not necessary. For example attached tops can usually be pulled flat against the frame that will hold them. But in this case I am making a box and any twist in a side will twist the box out of square.
One of the 10" candidate sides had twist. My jointer is 8". I put the board on a flat surface to locate its high corners, then marked them with chalk. It took literally seconds to clip off the high corners sufficient that the board would not teeter on the thickness planer bed while surfacing. The key word here is sufficient. One does not have to plane the whole surface to get it flat enough for thickness planing.
Re: Spice Box - 1. Face flattening boards
William Duffield
Question on twist: I assume the two corners marked with chalk are the high corners. How would you use the power jointer to take the twist out of that board? I know how to do it if the board is twisted the other way. But with a clockwise twist, I only know the scrub plane method.
