Grizzly mobile base quality (poor)
Cameron
I have acquired a bunch of grizzly machines over the years and although these machines are far from top tier, for the most part I have been satisfied with the quality for the money (exception is my older 14" bandsaw, really not a good machine.) I've recently emptied my whole shop for a long overdue concrete floor replacement and while moving my table saw, three of the wheels on the shop fox mobile base disintegrated to the hub. It turns out grizzly used hollow wheels and every single one in my shop has failed. To make matters worse, the bolt patterns are not standard and thus there is not a single replacement caster available to replace the faulty wheels (the holes are close enough that they would not be able to be redrilled, would have to hit them in a mill or use a torch...). I had to buy $150 worth of heavy duty, solid swivel casters, remove the wheel and install into the original shop fox housing (several of which were bent...). Very disappointed in this and lighter in the wallet...
Re: Grizzly mobile base quality (poor)
is shop fox the same as grizzly?
Re: is shop fox the same as grizzly?
cameron
They are owned by the same guy and a good portion of Grizzly's catalog is (or at least used to be) shop fox. The mobile bases that they solid to accompany their machinery were branded shop fox
TomD
Not saying it would have worked here, but sometimes we just replace wheels with a large ball bearing cartridge. One of our more versatile moving things is just a metal bar with a large ball bearing over the ends.
