oak plywood in exterior door
cameron
I am about to make some sliding carriage doors for my shop. I have some left over 6/4 white oak that I was planning on using for the rails/stiles and I was thinking about using 1/2 oak plywood for flat panels. I'm fairly certain that the oak plywood generally available is red oak (don't think I've ever seen white oak plywood) and I know that red oak is not suitable for exterior applications. Does the fact that the red oak would be plywood change it's compatibility for an exterior door panel? Thanks
Re: oak plywood in exterior door
Tom
You may have a problem with the plys delaminating because the glue is not for exterior use.
the myth of red oak weathering
I have heat wood red oak gates that are more than 20 years out in the weather.
Don't worry about the wood, it is the glue that is the weak link
Straw Poll
David Yoho
The biggest difference between red and white oak's durability in wet situations is their cell structure. The best way to picture red oak's cell structure can be to imagine a bundle of drinking straws. White oak's is different and mainly why it's commonly used for barrels and such. However, since you are talking about plywood that has a thin red oak veneer, this issue is minimal.
As others have already said, the problem with using the plywood for a door panel is totally about the type of glue used between the plies. Your plywood is not rated for exterior use and would not last.
Off the top of my head a better solution would be to either make your panels from solid white oak or medium density overlay (MDO) plywood, which is commonly used for outdoor signs. Of course the MDO with its paper outer layer would have to be painted. If I were fighting a budget, the white oak panels make better sense due to its lower price.
TomD
Exterior andmarine ply have waterproof glue, interior may not, but often it does. You can test it yourself, get a scrap, and throw it in a bucket of water for few weeks, see if it peels easily. If the oak is over a chip type core forget it. Using epoxy will make just about anything waterproof, but in clear applications, it can yellow, and degrade.
Frame and panel construction for exterior
Dick Coers
Frame and panel construction, for exterior construction has the danger of trapping moisture in the dado. Rain runs down the panel, and very easily wick in the groove. This will make plywood panels even more susceptible to delamination. A fine bead of quality caulk, or weep holes drilled to the bottom of the groove may help. I love wood, but will always choose fiberglass or steel for my outside doors.
