OT - Getting recording off DISH
Terry Alexander
I have a DISH recorder/box (whatever you call the thing). It is on the "fritz" and they have sent me a new one. However, I have some recordings on my current one that I sure would like to save. Does anybody know a way I save them or transfer them to the new recorder?
TIA
Terry Alexander in West Texas
Re: OT - Getting recording off DISH
Ray - Middletown, IN
I was able to hook up a standard external hard drive to mine. It reformatted it to the DISH format and then copied the movies onto the external drive. Bad thing is I have not been able to reformat it to use with a PC.
Ray
Bill Howatt
Have you tried Windows Disk Management?
Drives that don't have letters assigned to them for any reason will usually be displayed there. You can right-click on its graphic display and format it.
Bill
del schisler
on the fritz doesn't say much, will it turn on ? what doesn't it do, like show channel's picture? record , play ? if it play's your recording's on the tv now ? if it play's your recording on the tv or, can't you just set the new one up to record , now the new one will have to be hook up to the tv to see this, now the old one will have to be hooked up to see the play back , now when both are doing the record and play back , hook up the coax jumper to each other , like the output to the input both are hook up now , i belive this will work , i have done this on other unit's, booth have to be doing their own thing , like recording and other playback, try this , check back and let me know how you did
Bill Howatt
I'm assuming the thing on the fritz with the recordings is his DISH satellite receiver with a built-in HD to store the recordings.
I don't have DISH but Bell Canada's system is really DISH components although they have their name stuck on them.
I don't think there is a way to do as you suggested with my receiver because the only input it has is the coax cable from the satellite dish LBA and this signal isn't in the TV channel band. All other connectors are outputs such as HDMI, AV and on some Component Video.
Bill
del schisler
you use the input to the tv to the input on the other unit, i do satalite so i know where you are at, the lnb input is sig. in and it is converted to what ever chanel you are watching, and when recording it is like the old recorder's of yrs ago were used, if most people don't know , about electronic's i been in repair for 50 yrs but retired now, i use my satalites for dish and direct, and used to have BELL also but they moved the transmitters on the satalite up north so the usa doesn't get BELL any more only on the border can get the chanel's , thanks for reading
