Ink stain Question
Ink stain Question
Ink stain Question
Screwing up as fast as I can.....
I washed my sheets and a couple of shirts. Did not notice the ball point pin either already in the washer or in a shirt pocket. Sheets came out with blue blotches. Considered trashing them, but they are high thread count expensive sheets. Figured I would wash them again To reduce the chance of transferring ink to me in my sleep. Then I noticed a can of Spot shot carpet cleaner in the cabinet. Sprayed some on and it liberated huge amount of blue juice. That got on top of the clothes dryer and apparently etched into the paint. So now my white dryer has a blue blotch. Tried to wipe it off. No luck. Tried soaking it with the carpet cleaner, Nothing.
Anybody got a suggestion of how to remove the blue from the dryer?
(At one point I had blue hands...)
Re: Ink stain Question
Think about what you are needing to do
Adding a solvent simply dilutes the ink and with more volume it just spreads. To be rid of the ink color you either need to bleach it colorless, a process that busts the big colored molecules into smaller colorless molecules, or you need to TRANSFER the ink from sheet to something else.
To transfer the ink you need a good ink solvent and something the ink likes as well or better than the sheet. Wash the ink from fabric to absorbent with a flow of solvent. Start flowing solvent outside the ink spot and work toward its middle. The absorbent might be another fabric, paper, clay.....what ever works.
You may be able to bleach the metal surface. It is not obvious how you will transfer the ink.
Re: Think about what you are needing to do
You are correct of course. I knew when I did it that I should have rested the sheet on paper towels, but I did not. I was in a hurry for no good reason and blasted it with the carpet cleaner. I was stunned at the volume of diluted blue I got from it and then surprised it stuck so tightly to the painted surface on the dryer. If the dryer had been one of the old porcelain models it would have been harmless. I initially assumed I would never get all the ink out and just wanted to reduce it to the point it was set in the fabric and would not transfer. Just did not want to wake up as a Smerf or one of the infamous blue spotted leopards.
You may have to live with it.
Gary Smyth
Did the same thing. Pen in pants pocket. Washer water and detergent released a good portion of the ink and when placed in the dryer it heated it in. Pants and majority of the whole load were history as stain was muted but permanent. Dryer drum is white porcelain and the blue spots and streaks "heated" in for good. I tried to bleach it out and full strength household bleach lessened the blue shade but still there on the drum and especially the plastic "paddles". After scrubbing with bleach the stain has not transferred to other clothes, but the spots remain. Next time stainless steel where soaked steel wool might be possible.
Its good they don't let me handle.....
hand grenades.
After trying carpet cleaner and washing the sheets again, I tried lacquer thinner. The ink on the sheets was in spots, almost crusty. Lacquer thinner melted it and it bled out in copious quantities. Took them outside and poured thinner right through the spots. Did a great job. 99% gone. Faint stains left. A little unsightly, but no fear of it transferring onto me or my jammies.
Then I realized I had gotten on my shirt.
Back through the washer again.
thanks for the chuckles
I'm here all week, please tip your server
I've only told about half of this comedy of errors. I am going to have to wait for the ink to wear off my hands.
Re: I'm here all week, please tip your server
What is an "infamous blue spotted leopard?"
Ask the ladies, its the one.....
that tries to slip up on them amorously from the other side of the bed only to get laughed at for being covered in blue ink spots.
Re: Ask the ladies, its the one.....
Jack Prescott
Acetone will generally dissolve most ink stains from pens and markers.
I got out my carefully stored can of Acetone. It had all escaped. That's why I went with lacquer thinner. There was a learning curve here. One, don't do it. Check the pockets before they go into the wash. Every time. And have some acetone on hand. If using lacquer thinner, Pour some in a dish and dip the stained area. I poured mine straight through the cloth, and it worked well, but used a lot of thinner. And, don't do it on top of the dryer.
One piece of good news, The bleach worked. I put a paper towel on the stain, soaked it in bleach and covered it with plastic to retard drying. It appeared to be doing nothing, but later when I checked, the stain was gone.
Kodak photo flo
I do t know if you can even buy the stuff anymore but Kodak Photo flo solution that we used to dry film without water spots was the best stuff I ever found for removing ink pen stains from clothes.
Steal Ink Remover
David Yoho
Barry the factory I worked for used a spray can product called Steal Ink Remover. That stuff removed ink and many other things. You might have good luck finding it at WW Grainger in town.
amazon has  Kodak photo flo
del schisler
you can still get it at amazon , i used to work at a photo lab in my custom room, here is the link
