dull wax?
mike mcnerney
Is there a wax that will give you a non shiny finish?
I'm visualizing a typical satin poly look or maybe even dead flat (0 to 20)
dull wax?
mike mcnerney
Re: dull wax?
Keith Newton
Mike, you might try this. I've not ever used it, but seems like a good option. What could possibly go wrong??????
You can also find Rat Wax for autos.
Only one I know
David Yoho
The only wax I know (not that I know all waxes) that will leave a satin look is possibly Watco Satin Wax. However, it's not for application over a film finish like you might use a paste wax. I can be used over an oil or stain.
Briwax
Kneale Brownson
I've used the "Teak" version of Briwax and the result is a satin-like sheen.
General finishes *LINK*
Dick Coers
Makes a satin finishing wax. I don't know if it meets your sheen level.
http://generalfinishes.com/retail-products/furniture-repair-and-maintenance/satin-finishing-wax-polish#.VDafvN08KK1
Re: Briwax
Howard Acheson
Be careful using Briwax. The Briwax Original uses toluene as it's solvent. Toluene is an aggressive solvent and may cause damage to newly finished surfaces finished oil based surfaces.. I don't know it it's still the case but Briwax used to recommend not using it on surfaces less than a year old.
A few years ago they came out with a new formulation called: Briwax 2000 that uses mineral spirits as the solvent. It will not damage fresh oil based finishes.
Re: dull wax?
mike mcnerney
Thanks everyone, I missed that one in the LV cat.
