Pyrography from a Battery Charger
Larry
I'm look for a article for making a wood burner out of a car Battery Charger. I think it was in the Aug/Sept. 2012 issue of American Woodworker.
Thanks
Larry
Thanks
Re: Pyrography from a Battery Charger
Stuart Johnson
I have a pdf. file showing the Piddle burner. I can't post it here but will email you a copy if you want.
William Duffield
If you don't get an answer to your satisfaction here, ask on the turning forum, or ask Google to search for Graeme Priddle.
I think this might be what you are looking for:
http://www.woodturnersresource.com/extras/projects/priddle/WoodBurner.html
Do your search for Graeme Priddle wood vaporizer and you should find it
You can post PDF files here
Click the little blue circle with the question mark in it. It tells you what kinds of files our software supports and how big a file may be.
Re: You can post PDF files here
Stuart Johnson
Thanks, I didn't know you could post .pdf but I should have used shouldn't instead of can't. I didn't think I should post publicly something that I copied from somewhere else.
Ah, rights
Thanks for your concern about copyrights, Stuart. It's true that we don't want other people's intellectual property being posted here without permission. Sometimes permission is easy to get though. If ever you see a benefit of posting a photo or document whose copyright belongs to somebody else, think about emailing the person or organization to inquire about one-time rights to post it, with or without attribution if requested.
If this document belongs to Graeme, let me know. He is a friend who most likely wouldn't mind if we disseminate his material here.
Cheers, and thanks again for your caution,
