Router OT Help
Router OT Help
Router OT Help
Gary Smyth
Router stopped last night. Worked at 5:00PM and 8:00PM and not at 9:00PM.
Computer message is I am "not connected to the internet".
Called Comcast and then Netgear and after 45 minute wait was told that I was 20 days out of 90 day warranty and for $220 for two years they would straighten out software. Kinda got me upset.
Took my Ethernet cable and inserted it to my laptop running directly from modem to laptop and got internet but then lost all wireless as the router is out of the loop.
Running Windows 8.1. and Comcast provider. NetGear router appears to have all lights working properly so I think it is software.
Went to tools, internet options, and then stymied. I'm pretty sure this is a reconnection and click, but don't know where to travel to check out possible solutions.
The only thing I'm certain about is NOT spending $200 at Netgear.
Any suggestions/web site guide that might help. I'd like my wireless back especially for printing.
Re: Router OT Help
Re: Router OT Help
Dustmaker Mike
Get the model number off the router and go to Netgear and look for firmware and software updates. You should be able to do it yourself. Also there should be a master reset you can do to it to brong it back to factory specs.
Re: Router OT Help
Re: Router OT Help
Jerry Nicholson
I find that stuff like routers and MODEMs tend to fail after 2-3 years. I am using a D-Link wireless N router and I paid a lot less than $200 for it. The model I am using is currently $54.99 at Amazon.
The problem might be firmware in the router but I would suspect hardware failure.
A friend and I bought our first cable MODEMs, the same Motorola model, within a week of each other and when they failed it was also within a week of each other.
I think I am on my third MODEM and my third or fourth router.
Jerry
Re: Router OT Help
What did you reboot after that message?
Dick Coers
At least twice we had to reboot the comcast box. Did you shut it down, wait, then restart?
Re: Router OT Help
Same here...
John in NM
Only mine is a DSL modem/wireless router. I often need to power cycle it if there is a momentary line power drop. Sometimes also if the internet is horribly slow.
So first thing to do is power cycle it and try to reconnect (how ever one does that with Windows). If that doesn't do it then perhaps a new router is in order - or a new cable modem, if you can determine which is the problem.
In linux you can ping the router using a terminal window and the router's local address - that tells you if the problem is the ISP's or yours - but I don't know if such gritty details are still available in the more polished OS's.
Re: Router OT Help
Re: Same here... *LINK*
Stuart Johnson
This link should allow you to connect router and see the issue. At least it is what works for my netgear.
http://www.routerlogin.com/
NetGear Router Info
Re: Router OT Help
Re: What did you reboot after that message?
Gary Smyth
Yes, twice. Shut down computer-off Disconnect modem - wait 60 seconds plug back in, start up. "not connected to internet."
Disconnected Ethernet cable from router put into laptop. Have internet connection.
I thinking it has to be router
Re: Router OT Help
Re: Same here...
Gary Smyth
Both links provide message "This page cannot be displayed"
Re: Router OT Help
Re: Same here...
John McGaw
Have you tried connecting through the router via ethernet, skipping the wirless for the moment? Virtually any wireless router will have at least four wired network ports. If your router was set up in the proper 'safe' way then you probably can't expect to get to the management pages via wi-fi and will have to go the wired route. Do you know anything about how the network was set up in the first place? Network segment, etc?
Re: Router OT Help
No, not yet
Gary Smyth
I did get to a Netgear site and there is a way to reset to factory settings by inserting a pin. Problem is if I do that I lose existing information, such as ISP username, ISP password, IP addresses, wireless security keys, and ports or services that were opened. I do not know how to recover that or where I go if I do get it to reinstall it.
Re: Router OT Help
Are you sure the bit is tight in the collet?
Re: Router OT Help
Re: Router OT Help
William Duffield
Sounds like built-in obsolescence timers (software) to me.
Re: Router OT Help
craigd
craigd
I can't tell from reading your response, but did you power cycle the router? It sounds like the cable modem and wireless are working (do you have a cable modem, router and wireless access point (my setup) or are they integrated?) I ask because sometimes I'v seen my cable modem stop talking to the router and/or the cable modem stop talking to comcast and a power reset of both has fixed things. BUT if you can access the internet then the comcast side of things is OK (as much as I love to blame them).
I've had good luck with routers and cable modems, as in 10 years or so (I junked my old Netgear when they wouldn't fix a bug and got a Netgear). Of course, now comcast is telling me I need to upgrade my cable modem but won't tell why.
Re: Router OT Help
Gary Smyth
I have three items. Arris cable modem. NetgearWNDR4000 router. HP laptop.
Right now the cable modem is working as internet between modem and laptop is operating normally. The Ethernet cable goes from the modem into a USB port in the laptop. The router is out of the loop.
If I take the Ethernet cable from the computer and insert it into the router (as it was working two days ago) I get a message that I am not connected to the "internet".
The router seems to be working and has been powered down and reconnected several times. The modem is working and it too has been powered down with both it and the router disconnected and then reconnected. I get the same message "not connected to the internet".
Netgear has now amended their offer--$125 for a one year contract. They assure me it's a simple fix UNLESS the router is broken. If that is the case they will replace the router for free (10 day delivery) and then refund the $125. But they "don't think it will go that far". I'm convinced that both of us believe it is a configuration cleanup but I have been known to be in error. I just hate to spring for over $100 for a device that works and is less than seven months old.
Re: Router OT Help
craigd
craigd
I think you have done a good job isolating the problem (to the router) and $125 is adding insult to injury. For the most part routers just work - plug them in, they auto config and bits flow (I do get paid to mess with this stuff). The user does need to configure the security stuff, which can be a PITA. That router looks pretty nice but is quite expensive, most home networks don't need anywhere near those capabilities. I took a quick peek at reviews and the firmware release notes and don't see any issues like you are having.
*If* the router isn't broken, one possibility is the radio in the laptop isn't working or is turned off (which I've done a few times), check the light and/or see if it wants to connect to the neighbors [wireless] network. Given that the antenna is internal, it is probably connected. The other not-very-likely thing would be the [CAT 5 or 6 Ethernet] cable between the router and cable modem is broken. I'm also assuming when powering router, the light indicating connection to the cable modem to the internet doesn't come on or flashes (there is usually a well defined sequence of lights as the router initializes connections to the WAN (ie comcast)).
My suggestion would be to take your laptop down to Staples (or such) and go router shopping (so you can see it work with YOUR laptop), [consumer] routers are commodity electronics and I've found them quite reliable. A nice one (but not as capable as WNDR400 but just as fast) is probably around $75 or so.
For your setup the WNDR4000 seems like overkill and probably offers more than your computer/other networked devices can take advantage of. I'd suggest looking at a basic name brand wireless-N four port router, you don't need gigabit ports. Remember, Comcast is the bottle neck, any router is going to be faster than them and unless you are streaming video or huge files over the network, wireless-g is usually fine (and then using a cable is vastly faster than any wireless). If you are watching Netflix via the internet, it really doesn't matter what your network gear is, it is going to be faster than Comcast.
Most important is coverage, so all of your devices can connect.
