Wifes 8 yr old Dell desktop is acting up. When she turns it on the green light flashes on and off, and it won't connect. If I hold the button in for a few seconds it will usually connect. Some of the time it takes a few repetitions . Does this call for a new switch, or should I junk it?
I agree with John, more info needed especially about the term, "connect".
I'm assuming you mean it won't stay powered on and if so, then a new switch isn't likely to cure it. The power switch on a computer is a momentary contact switch and the actual power application is controlled through the motherboard and power supply.
I've had a similar problem in the past. Google your model. Some mother boards will flash an LED to display the particular error (like Morse code). Could be something simple. Some units won't booth without the case together (micro switch somewhere), etc. Good luck with it. These things can be very frustrating. For me, a computer is an appliance, not a hobby. I just want to use them, not play with them. I just ordered a laptop with Windows 8, so I'm dreading figuring that out. Oh, for desktops, I usually just connect the old drive to the new pc as a slave. I then transfer everything over as needed. Hard drives are like closets - you collect an amazing amount of junk you don't need on them!
Funny, I used to wonder why anybody would need more than one computer...now we have three, smartphones, etc. Geez.
Hope you get it figured out without to much trouble.
The problem is probably not the switch as they seldom go bad. If your power-on light (green) simply turns on and then off (red) that's one thing but if the green light comes on and blinks several times before going to red and off then it's giving a blink code, which some computers do for troubleshooting purposes. Most blink codes can be found for a given model on the manufacturer's website.
If you are not seeing a blink but just green on then red off, there are two possibilities to check before suspecting the mainboard. First, the CPU cooling fan may be getting weak or the cooling fins on the heat sink are full of dust causing the CPU chip to get too hot at which point thermo protection shuts the unit down before burning up the chip.
Second, the power supply could be going or has gone bad enough to need replacement.
My experience with Dell desktops of that age has been they use a single fan plus a shroud to cool not only the case but also the CPU. Fist order of business would be to make sure dust and dirt are not blocking air flow.
If you have not done it yet its a good time to backup all important files before the hard completely gives up. As was mentioned before check to see for dust buildup on the fans for the power supply and cpu. I would suspect the power supply is failing. Try running a diagnostic with the computer running. Maybe Belarc or similar.
My wife just went from Vista to Windows 8. You can run Win 8 in desktop mode so it looks like the old version. I've played with it some while getting her set up and I think Win 8 will be just fine once/if it is figured out.
I had a Dell, and had to replace the power supply as it got old. I just went in and bought a PS for about 10 bucks and plugged it in. Fired up after that. In my case there weren't any warning lights it just wouldn't fire up. The PS I bought didn't fit (anticipated this might happen), I just closed the case part way and draped mos. netting over it. Got another few years out of it. It was always a noisy computer but the replacement PS was quiet, and a lot nicer to live with.
Two things are: 1) I used to be on the board of a charity that recycled computers, but today, I wouldn't let a hard drive out of the house. I keep them for partial archival reasons, I have a HD unit that allows me to power and connect them. And for privacy reasons I would never let them out into the world. 2) (to whom it may concern) I have older parents who are getting to the point where they are metaphorically wandering the streets of the computer lost, and in their bath robes. Don't hang onto an old computer for so long that it crashes when you are feeble and can no longer learn a new system. Computers are great, and they ought to be of great assistance to old people, but my observation is that the opposite is what actually happens, they become an incomprehensible nightmare.
When I need to get rid of an old hard drive, I tear it down and rub powerful magnets all over the disk surfaces. I then scratch the heck out of the disks.
I like Win 8 on the desktop especially after the 8.1 and subsequent update. You can't even tell my computer is likely running Win 8 after it boots up (which is a lot faster) unless you can see the purple icon in the lower left corner of the screen.
Start Menu? I actually prefer to right-click on the purple icon mentioned above. Everything I want such as Control Panel, Disk Management, and then some is available and for what I do is much better than the Win 7 Start menu. I never used the "last file opened" feature on the Start menu.
You don't have to use the fly-out charms in the Metro interface unless you want to. Pretty well most applications will place a short-cut icon on the Win 8 desktop and if it doesn't you can do it yourself just like other versions of Windows. You don't have to use the Metro Start Page unless you want to.
Using the Metro applications are different and require some learning if you want to use them but after you do they aren't all that bad to use but I've found some of the Metro versions lacking in the features I'd want on a desktop.
