After about 45 minutes of fairly heavy work ; repetitive cuts of softwood 4 x 6, but with a few seconds break between each cut, probably still no more than 50% use. My SCM started to give off a whiff of that dreaded burning out motor smell, and when I felt the gear box it was hot also. The saw is about 4 years old, it has seen a fair bit of use, but by no means commercial levels of use. If I send it in will I be told it needs a new motor? Could it be a lubrication issue? Anyone had similar experiences? Thank you.
Do you have shop air? If so blow out the motor if not then get cans of canned air. That is where I would start. After that I would look at the brushes.
The brushes. Have they been making a frying or arcing sound? Sometimes one will stick, or a spring will break, causing it to make poor contact. If you look into the end of the motor when you turn it on, you will probably see the arcing if this is the problem.
Unplug it, then take them out for inspection. Usually a corner will be broken off as they go bad.
While you have them out, look down in the hole and turn the blade by hand to se how the commutator looks. Sometimes one of the little bars will loosen, which wrecks both brushes, causing them to both arc, which can cause a lot of heat.
If you don't see anything wrong with the brushes, it may be dry bearings or gears down on that end.
change the brush's , i belive that when you stop the cut the motor tries to reverse stopping the running, if so the brush's go bad quick, if they are pitted on one end of each or broke off , that may be the problum, my LS1020 goes thro brush's fast that is how mine stops the cut,
John, Your first line, "After about 45 minutes of fairly heavy work " may hint at another problem.
Back many years ago when power miter saws were fairly new to small operators, somehow the common name got changed to "Chop Saw" in the common jargon, which I think led some craftsmen to believe that is how they should be used. I've seen some guys hit the switch, then slam it down through the wood. I'm not accusing you of this, but just so you know, I think this can lead to problems.
Anytime you overload a motor, the amp draw goes up, which will increase current crossing between the brushes and commutator. Over a period of time, this seems to lead to a black glaze forming on the commutator, which I guess causes resistance, leading to more heat and less power.
Otherwise, I don't think there is any way that universal motors slowly fail, on the electrical side.
A few months ago, I was helping a couple of friends build some fixtures for their new office. They were busy cutting some steel square tube. One of them being a contractor, son of a home builder, doesn't always show much sensitivity to tool usage. They were forcing the abrasive cutoff wheel so hard that their motor rpm's were probably about 50%. I was working on something else when finally they had decided to go buy a new saw, since this one was loosing power.
To help them out, I grabbed a Tommy stick out of a drawer and dressed the commutator, and a diamond wheel dresser for the wheel, then instructed them to listen to the motor while I made a few cuts. It was cutting just as good as new for me. Both of them looked at each other and admitted that they didn't know.
I might add that lots of new woodworkers tend to be the other way, and cut too slowly. So for them, I might add that you should hear some reduction in speed to keep the blades happy. Saw teeth need to take a large enough chip, for the chips to take the heat out. This also applies to router bits, shapers, and band was blades.
It is a very soft, or loosely bonded abrasive stick which breaks down when you stick in an opening while the tool is running, and touch the commutator. The grains clean up the commutator, and perfectly seat the ends of the brushes.
I'm not sure if that is a brand name, or where I got them. I would imagine that the parts suppliers have it, but I wouldn't expect to find it an a hardware store.
