Anybody tried the Camo Deck screw system?
I put new boards on my front stoop. Used the composite material. I stared at the Camo Screw system for a while and finally broke down and bought it. Discounted from about $90 to $47. Instead of about $8 worth of screws.
The system includes a "handle that has a driver mounted through it with a little indexing ridge one the foot that helps position the screw. You insert one of their special screws, position the driver, and with your drill attached to the top of the shaft, telescope the driver and "toenail" the screw in through the edge of the board. The instructions (yes, I actually read them carefully.) indicate it is made for pressure treated wood deck boards but is also suitable for composite material and hardwood. Supposedly designed for no space between the boards and invisible screws in the edges.
I decided to make a practice run. I had some scraps in the shop. I couldn't do anything with it. I could not make it drive a screw well. I decided the composite was too hard for the screws. Out of curiosity, I tried some treated wood boards. No better. (The treated wood was old and dry)
The screws look like trim screws, with small heads, about a 1/4" in diameter. The business end looks like they cut them off with a pair of pliers. I think they would have worked if the screws had a better drill point on them.
I gave up and went back to the old fashioned screws. Took the Camo things back and got my money back.
Anybody tried the Camo system and had better luck? Did I miss the secret?
Re: Anybody tried the Camo Deck screw system?
Mark Nowicki
I built my 400 sq.ft deck with them. I used 5/4 cedar deck boards on treated frame boards.
I have driven CAMO screws into plywood and hardwood flooring without the guide. You are right about the dull point , but I have not found it to be a problem.
I use a Makita impact driver.
I really like this system.
Mark
Mark Nowicki
I really like the system.
Mark
sorry about double post.....
I was using a Bosch Impact driver. Not sure why I had so much trouble, but I think the hard wood was the problem. The composite deck boards were harder than most wood and the treated wood was dry and hard.
Yes and it was very good
Jay Lombardo
I just finished using the Camo system on my 700 sq. ft. deck. I installed a composite decking material and the system worked like a charm. They have 2 sizes of bits for the screws. One for solid composite or wood and a slightly different size for slotted composite boards, both work equally well. No visible screws on the face of the boards. The difference in price from the board manufacturer's (Fiberon) hidden fastener system was a little over $500!! Camo cost me a little under $200 including the installation tool and Fiberon's was about $700. Tool only cost about $40 and spaced everything perfectly. Kind of a 2 man job to keep spacing perfect but that was more due to slight wiggles in 16' boards than a problem with the tool, I suspect I would have had same issues with the $700 system. Anyway I highly recommend it. One caveat, some manufacturers approve this system for their warranty and some do not. I know Lumber Rock does but Fiberon does not. After talking with the Fiberon manufacturer I decided their reasons for not approving this system were ridiculous since screwing through the face was an approved method and used it anyway. This stuff has a 25 yr warranty and I don't see how toenailing screws into the side is going to affect it any worse than screwing into the face. sorry for being so long winded but I really liked this system.
