OT: How to check a Porter-Cable 8604 14.4 charger
Ron Berlier
Greetings all - Can someone tell me how to check a Porter-Cable Model 8604 14.4 volt battery charger to see if it is outputting the correct voltage? All help welcomed, thanks in advance.
Ron
Re: OT: How to check a Porter-Cable 8604 14.4 charger
Not familiar with chargers, but
in general, measuring output for anything involves a volt--ohmmeter, nowadays also called a multimeter and available at your local hardware store or Radio Shack. You then have to figure out which of the two contacts actually generates voltage; other contacts will be used for controlling the charger in some way.
del schisler
a volt meter set the meter on a voltage higher than what you are checking, don't know the setting's on the meter you will be using, their are 2 pin's on the charger , the pin that is closes to the back of the charger on mine is a minis and the other is the postive, put the prob's on that way , if the meter go the wrong way like it doesn't move up the scale where you can see what the voltage is reverse the prob's, it will measure more that the 14.4 voltage due to no load on it, it may read read maybe around 20 volt's , don't worry that will be normal, i been in repair for over 50 yrs , so know about this stuff, is the battery not taking a charge ?? is the little light blinking on the charger if so the battery may be low in voltage and not enought to make charger work, just a thought good luck check back with up date
Ron Berlier
Thanks for the feedback. My charger has three 'pins'. Reading from the center pin to the left I get 12 volts. From the center pin to the right I get zero volts (?). The batteries don't seem to hold a charge for very long - not as long as when new anyway.
del schisler
charger isn't putting enough voltage out , should be more than 12 volt, that may be why the battery's aren't charging up, any way to get another charger and check voltage, or better yet call the company and see if you can get a person in a dept that may be able to tell you more , but my guess problum inside charger , is their a repair place that does repair on equiptment drill's and charger ??
Jason Roehl in Lafayette, IN
It's the two outside pins. The center pin has to do with a thermistor to determine if the battery is too hot or cold to charge. It's been a while since I messed with my P+C 14.4V chargers, but I believe the output voltage is just over 17V, or maybe that was the voltage on a fully charged battery.
My experience was that those P+C 14.4V NiCd batteries didn't last all that long in terms of service life, maybe 3-5 years.
Jason
