Skil 5825 6-1/2'' wormdrive saw blade?
Charles Jackson III
I am wondering whats the best circular saw blade to use with my Skil 5825 6.5 wormdrive saw? I used it for framing projects and house repair jobs.
Re: Skil 5825 6-1/2'' wormdrive saw blade?
Keith Newton
For cutting new material I would use Freud D0724A Diablo 7-1/4-Inch 24 Tooth ATB Framing Saw Blade with 5/8-Inch and Diamond Knockout Arbor. For around the shop, or out on jobs cutting plywood, I am more likely to change up to 40 teeth. Then for cutting dirty lumber, with likelihood of hitting nails, I've been impressed with their demolition blade.
The price of these blades are so reasonable that you should get all three. There isn't any one perfect blade for everything. I'm about 40 years older than my assistant Ben, who before joining me here in my shop, was a "Timber Framer" as in post and beam. He showed up here with a worm drive, but never uses it here in the shop. I like sharing things about when I was his age, and I think he like hearing them. Back then when framing houses, at break time, I would flip my saw over, wedge the guard back and file the blade right on the saw, while we sat around with a snack. I think my first carbide blade back then cost about $75.
what does the worm drive weigh?
Kevin French
My Makita weighs in at 14 lbs, cuts great and won't be going away soon
Re: what does the worm drive weigh?
Charles Jackson III
My 6.5 Skil 5825 professional wormdrive problemly weights 13lbs.
