Tabletop fastening question
Bruce, a MN Galoot
I'm in the final throes of building a cherry trestle table for some friends. They provided a stack of rough lumber, unfortunately only 1" thick, so the final thickness of the top is 3/4".
My question is, are figure 8 fasteners strong enough to attach the top to the base, assuming the table will only occasionally be moved but likely by lifting from the top? The trestle base is about 40 pounds, and the solid top is 38" wide.
Thanks.
