Glue for Rosewood
Glue for Rosewood
Paul Kramer
Glue for Rosewood
Paul Kramer
All,
I'm making this wall-hung shelf for my sister. The corners are joined with full-blind mitered dovetails. It will be hung from the wall with a modified French cleat. My question is how do I best glue the cleat to the underside of the top?
I tried to glue a splinter back on that came off while planing with yellow PVA glue and after an hour in clamps it just fell off. Would clamping it longer made a difference? Is pre-glue preparation with acetone or something necessary? Would another glue work better? Is a mechanical connection necessary (tongue on the top of the cleat and groove on the underside of the top) the only choice?
Thanks in advance for any help you can offer.
Paul
Re: Glue for Rosewood
Keith Newton
Washing down is recommended, and after just one hour in clamp, the glue thought it was still in the bottle. The cells of a wood like this are so dense and full or resins which resist water absorption, I've found the glue still wet after 12 hours.
Easier than routing a dado, I'd drill and screw up from the bottom, then plug the holes.
Gluing Oily Exotics
When I worked rosewood (or other topicals), the glue-joint got wiped/scrubbed with acetone or lacquer thinner to remove the surface oil and then I used epoxy and left it clamped over night.
paul woolson
As a guitar builder, I use a LOT of rosewoods. One of the questions I'd ask (and you might not have an answer) is, "what kind of rosewood do you have there?" They are vastly different in their properties. East Indian rosewood (Dalbergia latifolia) performs pretty much like many domestic woods. Very little oil unless it is heated, then lots of resins leach out from it. But it glues with PVA just fine. On the opposite end of the spectrum, Cocobolo (Dalbergia retusa) is extremely oily and really won't glue well with PVA. In this case an acetone wash used to be recommended. However, it's been found (theorized) that the acetone will dry out the surface of the wood, then, once the glued piece is set, the resins can rise from the sub-surface and actually break the bond of the glue. So, unless it's and extremely thin piece of wood, and acetone wash is not recommended, because it's simply impossible to get all of the resins out of a board.
That said, with very resinous rosewoods, I've had good luck with roughing up the surface with 80 grit and gluing with epoxy, making sure I don't clamp tight enough to starve the joint. Keep in mind that epoxy with continue to creep for hours after you've clamped it, so you really just want enough pressure to hold the joint securely.
Paul Kramer
Thanks for the responses
Paul Kramer
All,
Thanks for your advice. I am told the wood is either Cocobolo or Honduran Rosewood. Given the behavior with PVA glue I'm guessing the latter. The wood is very resinous and waxy even without any finish. I went ahead and ploughed a groove for the top and cut a couple of mortises for ends of the French cleat. BTW I had another little chip and used methylmethacrylate (super) glue and it worked really well.
Thanks again,
Paul
