Finish for Ash?
Finish for Ash?
Finish for Ash?
Ron in Sterling, CT
I have made a set of book ends using a board of Ash I had laying around. I would like to finish them without stain. What is your favorite clear finish to pop the grain and show the natural beauty of the wood?
Ron
Re: Finish for Ash?
Re: Finish for Ash?
Bill White
Have you tried shellac on a test piece?
Bill
Re: Finish for Ash?
Re: Finish for Ash?
Ron in Sterling, CT
Bill,
I was thinking a very light coat of BLO, then shellac, but haven't tried anything yet. Thanks for the suggestion.
Ron
Re: Finish for Ash?
Re: Finish for Ash?
Yonak
My experience is that BLO doesn't enhance chatoyance. It does add richness to color and depth but not lustre or "pop" the grain. ..My own experience only.
Re: Finish for Ash?
Re: Finish for Ash?
If you'd like to keep the wood as light a possible, leave the BLO on the shelf as it will darken with age.
To get more "Pop" for your piece, raise the grain with a moist wipe. When dry (and fuzzy) mist on a spit coat of ultra pale dewaxed shellac mixed to less than a 1lb cut. This will stiffen the fuzzies and make it easier to scrape or sand them off. Follow with another coat of shellac at 1.5 to 2 lb cut. Allow to dry well and then top coat with a couple of applications of a quality waterborne finish like General Finishes HiPer Poly or Enduro gloss, or one of the Target gloss finishes.
Allow to dry for several days and then rub with a bit of compound to soften the gloss on the raw finish. I prefer gloss finishes because semi or satin finishes have flatting agents added to tend to muddy the grain.
Re: Finish for Ash?
Re: Finish for Ash?
paul in AZ
I'm sitting 5 feet away from an ash cabinet I built decades ago.
This was finished with nothing more than BLO and wax. Probably reapplied once or twice over the years but i can't be sure. I waxed it a few times but didn't use any sealing finishes such as varnish or shellac.
Initially of course it was pretty pallid.
The overall color is now that of a rich medium honey. Grain is readily visible and quite attractive.
I also have some custom made ash captain's chairs [not mine] about the same age that were likely sprayed with some clear sealer by the builder. They are now a sorta pale honey color.
My impression is that BLO should wind up with a slightly darker mellow color than unoiled wood.
Re: Finish for Ash?
Re: Finish for Ash?
David Churnega
That has been my default finishing routine for many years. In my experience the BLO darkens with age.If you want instant antique try "seedlac" shellac.
Re: Finish for Ash?
An alternate view
When I use ash it is because I want the look of a light colored wood. Hence, I try to preserve the color of "fresh" ash. To that end I used a "water white" finish. Many of the water based finishes are water white.
Re: Finish for Ash?
Re: Finish for Ash?
don stephan
Ash is somewhat open pored/coarse, so plan on enough coats to fill the pores if you want to be able to rub the finish at all. Ash is a great wood, I constantly pester my lumber supplier to start carrying quartered ash.
