A new design for the "DAAM" on a Music Stand
Alan Young
Alan Young
I have made several music stands over the last few years. One of the tricky elements in a music stand design is the Desk Angle Adjustment Mechanism. "DAAM" (I have found out that most music stand manufactures refer to the rack with a lip that holds the music as the "Desk") Most wooden stands I have seen utilize a rather clunky mechanism. A few years ago I came up with this design-basically taken from a pianos' music "desk"
I am working on a new stand and decided I wanted to see if I could refine that design and come with something even less visually obtrusive. Here is a rendering of the new design.
One of the pluses of the spring load pull-pin design is that the pull pin locks the stand in position so if the user has a heavy manuscript on the desk it won't tip forward. I have now made a working prototype of the design. The prototype is in aluminum with a steel pull-pin. The final iteration will be from brass- probably a steel pull pin. I made a couple of videos of this new design.
This video shows the parts:
http://www.youtube.com/watch?v=AvHzR_ws3xA
This one shows the mechanism put together and functioning.
http://www.youtube.com/watch?v=sQDCvSCQqas
-Alan
Re: A new design for the "DAAM" on a Music Stand
Merle Clor
Alan, I think that is quite creative and worthy of a patent.
William Duffield
That's a great idea, and a useful implementation. It'll look terrific in brass.
Did you design and build the adjustment mechanisms in your first photo? I guess you must have a mill (Bridgeport, or some such) for doing that work in metal.
Looking at your drawing, you do realize that you will have structural issues with the connection you show between the metal mechanism and the wood slotted molding on the desk, don't you? ;) When you finalize that part of your design, please show us how you did it.
Alan Young
Hi William-details
Alan Young
Hi William-Yes I designed and built that first mechanism- I have access to a Bridgeport and a Nice Metal Lathe
These renderings more accurately depict my intentions.
A brass plate will be screwed to the brass geared/notched plate.
Then the entire mechanism will be screwed to the center wood piece of the desk.
I expect this to hold up
-Alan
Re: That'll Work!
