Convert Jorgensen clamp to spreader?
Wayland
Hi-
I rarely have need of a spreader, and thus don't want to spend the money for one if I'll only use it once every 10 years. But now I need one in the 24" to 36" range. I'm thinking I might be able to grind off the rivets of the stationary head of a Jorgensen bar clamp, which would allow me to turn the two orange pieces around, replacing the rivet with a bolt. But I don't know if the bar will actually slide into the stationary head backwards without binding or otherwise not working. There may also be some other reason why this won't work. Before I make a mess of things, I thought I should bounce the idea off you guys and gals to see if anyone has tried it and if so, whether or not it worked.
BTW, a similar idea won't work with a 3/4" pipe clamp because the handle will hit the pipe and the pipe threads may not go in backward, since they're tapered. The handle would be ok with the 1/2" pipe clamp, but the threads may not work.
Thanks in advance.
Wayland
