REAL MILK PAINT
Which orientation for shelf dividers?
Bart Goldberg
Bart Goldberg
I'm building a book case of sorts - but will add some vertical dividers between fixed shelves to create "cubbies" in the top most shelves. Do you normally orient the dividers with grain running vertically like the case sides, or horizontally? I was thinking that having the divider grain run horizontally would cause some wood expansion issues, since the dividers will be trapped in dados between shelves. I was also thinking that having the end grain of the dividers showing (if run horizontally) would not be aesthetically pleasing as well.
Thanks
Bart
Re: Which orientation for shelf dividers?
Jim Hoeller
Run the grain vertical.
John McGaw
I've always seen it where the cross-grain of the shelves matched the cross-grain of the dividers. If your shelves have grain running lengthwise (and how could it be otherwise?) the divider grain would run vertical. Then, as the shelves change width with humidity, the dividers will follow. Actually, with normal conditions and average wood the movement shouldn't be noticeable but why take chances?
AZ in Colorado Springs
You could easily add edging to cover the exposed end grain, but I think that would look really odd.
Jesse Cloud
Run the grain vertically. Glue the dividers in the front of the dado only. Leave a little room in the back for movement.
William Duffield
Why not glue them the whole length of the dado? The shelves and dividers, made from the same materials, and the carcass itself, should expand and contract at the same rate and in the same direction. (Sliding dovetails would be a different story, but for other reasons, and I don't think anyone has proposed them yet.)
Uncle Jess
I dont see anything in the original post that indicates that dividers are the same material as the carcass.
William Duffield
You're right, but they both at least have grain direction, so that's the simplest, and most aesthetically pleasing assumption.
