Front porch post
Front porch post
Front porch post
Lynn Reedy
I need some advise on front porch post. I have 4 6x6 treated post
on my front porch. These post are in concrete on one end holding the house
roof on the other. We are currently painting and upgrading the front of the
house. I am planning to wrap these post with a better looking material. My
plan is use MDO to wrap the post. My 2 concerns are:
1. Is there a better material, cost considered, than MDO?
2. Are spacers needed between the post and the MDO for air flow?
Thanks for the help,
Lynn Reedy
Soddy Daisy Tenn.
Re: Front porch post
If you want low maintenance coupled with durability, I'd go with composite like Trex and others. Caulk the vertical joints and you won't need spacers but a weep hole or two at the foot couldn't hurt.
Jason Roehl in Lafayette, IN
A caution...
You don't necessarily need spacers for drainage between the 6x6 and whatever the wrap ends up being. However, don't just put a tape measure to the post and use that measurement as the short-face measurement of the wrap pieces--give yourself an extra 1/4-1/2" so that you can more easily make your beveled corners align even if there's a little twist or bow to the existing post. That is, if the 6x6 measures 5 1/2" on a side, make the inner dimension of your new "box" 5 3/4" - 6", more if the posts are severely bowed or twisted.
Jason
Lynn, I assume your climate in Tenn. is not very different from mine here near Richmond VA.
I find the bottoms of treated posts/columns rotted regularly, Especially the ones wrapped in concrete. Common on ones that are twenty years ls or more.
So, before you start, take a screwdriver with a 1/4" tip and probe them thoroughly. If they are starting to rot, that's your first problem.
Beyond that, Jason's suggestion of giving yourself some room is a good one. My experience is that most of them are a little twisted and crooked.
MDO is a good choice. At the bottom I might put "boots" on them made of the high density PVC foam to keep the MDO from touching the ground. I am a little skeptical of the PVC. I suspect that large pieces of it will crack from UV. (I have seen a few).
Keith Newton
I would use Extira before MDO. It is and exterior MDF, which might make the assembly easier than mitering the corners.
Like Barry suggest, make sure that your current post are solid on the bottom. Would also suggest holding the sides higher, then wrapping the bottom with a base trim. If you ever need to get back in there to possibly juice the bottoms of your 6 x 6 with ceps, this would make it less envasive to just remove the base trim.
