A week or two ago we had a discussion about putting carpet over laminate flooring. That and Mckay's post about installing a wooden floor in his shop got me to thinking. I have a room in my house that used to be half of a two car garage. About thirty years ago we converted it into an office compete with some dense short glued down carpet which is now very compacted and stained. The office is gone. How had is it to tear out glued down carpet? (I dread the thought)
The question: Can I put laminate floor down over this carpet? Its on a slab on grade.
Barry Carpet needs to go before you install laminate flooring. Then you have to ask what are you going to use that room for. If a living area then you ahve to make sure you put felt weather bearing or buy the laminate floor that already has the spongy backing attached to it and then yo do it like floating type which is easier to replace and remove. don't go gluing th laminate to the floor again. The other thing about the floating laminate floor is that you can install it your self with all the tools you already have. Just make sure that you sue kneeling pad when you go installing otherwise, you are going to be dwon on th floor for awhile because of your knees.
Barry Carpet needs to go before you install laminate flooring. Then you have to ask what are you going to use that room for. If a living area then you have to make sure you put felt weather bearing or buy the laminate floor that already has the spongy backing attached to it and then yo do it like floating type which is easier to replace and remove. don't go gluing the laminate to the floor again. The other thing about the floating laminate floor is that you can install it your self with all the tools you already have. Just make sure that you sue kneeling pad when you go installing otherwise, you are going to be down on the floor for awhile because of your knees.
I have installed lots of laminate in various houses I have flipped. Some of it, the cheap stuff and some of it the high end stuff. You are right abut the knees.
This carpet is so thin and hammered down I was wondering if it would make a substitute for the foam pad. (Can you tell I am Cheap and lazy?)
I have done many things that were "good enough". Somehow I have things that were good enough for me. We should be careful what we build, we are going t be stuck with it. Some of my shop cabinets were built out of sink cutouts a friend in the cabinet business gave me thirty five years ago. Functionally excellent, but a little silly looking. I could go on and on.
So, you are right. I should raise my standards and shoot for the best. After all its for ME.
Personally I would lay the thicker plastic under-layment made for laminate flooring directly on the carpet if the floor is level!
There are a lot of these floors laid over loose sand in areas where the underlying concrete was not level. Obviously the heavy plastic under-layment has some flexibility and give, probably as much as a compacted carpet! I have the "lightweight" plastic under one floor and the heavier material under my kitchen floor. Both floors have held up well for over 10 ~15 years.
By the way, if the room you are proposing is not in an area where water will be an issue (Bathroom / kitchen) don't glue the laminate together. The snap lock type can be repaired / removed / reused if there is no glue used. When laying it also pay attention to the lengths and layout, per the instructions there is a minimum length to be maintained at the ends. This is important as I have seen people ignore this rule and the ends do move and leave gaps with use, if short sections are laid at the ends.
