ADVERTISE HERE - FREE TRIAL
how to make a sliding door
Adrian
I want to make a sliding door, and I've seen two different suggestions about how to do it, one in a book on doors by Andy Rae and the other one in a Fine Woodworking article by Seth Janofsky. The former source suggests that you make a tongue on your door, make a groove in the case, and the weight is borne on the tongue, so the groove is less deep than the length of the tongue.
The second approach has you make a tongue and groove, but the groove is shallower than the tongue, so the tongue keeps the door in position, but the weight is borne by the rabbet, not on the tongue. One advantage is that dust in the groove is less likely to interfere with movement of the door.
Does anybody have any thoughts on which design method is best? Or does it make no difference?
Re: how to make a sliding door
I have made several cabinets over the years that had sliding doors. It seems to me that the one that slides on the bottom of the groove would be better if for no other reason than the wear would occur in the bottom of the groove and be less visible.
Actually, I used tracks on the last few I did. Some were plastic and some were aluminum. The plastic ones slide better.
Pay attention to the fiction factor. Also, sliding doors should be wider than they are tall and the handle or whatever you use to move the doors should be low on them if possible. (trying to make them less "tippy")
Thomas S Stockton
Adrian
I think either will work fine. It is a pretty low stressed application.
I've done them a lot of different ways using hardware and grooves and when using grooves the sliding surface is the bottom of the door.
Tom
Re: how to make a sliding door *LINK*
John McGaw
I would recommend the lovely little Klein system. I've used it and it works a treat and really requires not much more than a simple saw cut or two at top and bottom and a few shallow holes easily accomplished with a Forstner bit.
http://www.leevalley.com/fr/wood/page.aspx?p=40162&cat=3,43614,43620&ap=1
TomD
I like the Janofsky system. I think there is enough bearing that the material won't wear appreciably though those Krenov type projects are often made with very hard woods. A little wax goes a long way.
Adrian
I'm tentatively planning to use hard maple for my project, so the wood should be pretty durable. Tom, what do you like about the Janofsky system? Why do you think it's better?
Regarding the Klein hardware mentioned above, is it better than doing an all-wood door for some reason, or just easier? For this project I'm trying to do the best thing, even if it's not the easiest. I don't have a table saw, so I'd be cutting the "saw kerf" with a plane. Jankofsky recommends a groove that is only 1/8" deep, and a tongue only 1/16" long (leaving a 1/16" gap at the bottom of the groove) so cutting this is not a lot of work.
