Dead i-Phone tip????
My friend uses his I-Phone 4 as a camera an posts hundreds of things to e-bay and Craig's list to sell. Also uses it for a LOT of phone calls. It died. Dead as a hammer. Nothing. I called it. On my end it rang four or five times and went to voice mail. On his end, nothing. He pushed and held the button on top. Pushed and held the home button on the front. Nothing. He plugged it in to the wall charger, nothing.
Called his provider and the answer was to push both buttons at the same time and hold them for a while. By this time he had tried plugging the charger into the computer. Not sure that was part of the solution, but maybe.
So, His daughters acted like Dad might be an old fuddy duddy for not knowing this. Among the four of us over forty, none of us knew.
So, if you did not know how to reboot a dead I-phone, now you do. I wonder how many of you already knew this?
Re: Dead i-Phone tip????
William Duffield
It works on an iPad, too. I knew that, but I forgot. CRS syndrome, I guess; I am over forty, after all. I had to look it up in the user's manual. Now, I keep a .pdf copy of the manual on the iPad, in case I forget again. :b
Tim Caley
You have to hold down the button below the screen and the button on the upper right corner at the same time. After about 5 or 6 seconds your screen will go dark. Press and hold the upper right button till you see an Apple logo. Wait for phone to complete reboot.
Hope this helps resolve the issue.
John McGaw
I did not know that but I don't have an iAnything either. What I do know is that many times it is useful to RTFM (Read The Fine Manual) whether on old-school paper or online. Failing that, Google is usually your friend..
Jason Roehl in Lafayette, IN
Yep.  Knew it!
I'm on my third iPhone (due to upgrades, not failures), so I'm familiar with the process. I've also jailbroken all of them, so there has been an occasional crash, but only one that was somewhat severe.
Your friend probably needs to do an online search for iPhone tips and tricks. There are quite a few things that are really handy that he may not stumble across on his own.
Jason
If truely dead -> a decent burial.  Or sell it.
Kneale Brownson
No, put it on your iPhone so you can fix the iPad
.pdf
Dave Bair
How are you going to read that manual on a dead iPad?
Re: No, put it on your iPhone so you can fix the i
William Duffield
Sorry Kneale, my attempt at humor failed miserably, since you wouldn't know I don't have an iPhone. I don't get cellular reception here, so the cost of the iPhone and a "plan" just doesn't make financial sense. Instead, I have a very cheap Android phone, with a very cheap rate from Virgin Mobile, that I turn on only when I'm away from home, and that I haven't bothered to learn (and forget again) how to use.
Re: .pdf
William Duffield
That was the point of my sarcastic comment. If I have to go home to read the manual (available ONLY electronically), I may as well do whatever I was going to use the iPad for, on the PC instead. You'd think Apple would at least put a physical "Don't Panic!" button on the gizmo. Even Bill Gates admits that ctl-alt-del was a bad idea.
Further, the User Guide is almost worthless. They didn't even need to reissue it when they released iOS 7. It doesn't even contain the word "reboot". Yeah, they use "reset" instead, but we all know what "reset" means, don't we? The manual doesn't say.
