hole filling plug question
I am designing a "spice box" jewelry box for granddaughters. It will be smaller than the traditional boxes, which I think are too large to sit on a dresser handily.
The door will be decorated with line and berry. On a small box 1/4" "berries" are going to look too big. Does anyone know of a plug cutter source for smaller plugs, or a technique to make them?
Re: hole filling plug question
John Veerkamp
I just turn plugs to whatever size I want and cut them off with a Japanese flush cutting saw. Just did some for a mirror frame.
TomD
What about an annular cuttter?
Hollow wood screw extractors,
Dick Coers
or just file some teeth on the end of steel tubing. A bit of set in the teeth will keep the heat down.
Veneer?
I've never done this, but could you use veneer, and make the plugs with an arch punch, available from any leatherworker supply house?
Rick Snyder
Bill, I use a tenon cutter for my berries on a bible box I made
Rick
Being a turner you know what I'm going to say. Michael Mocho showed us a really good way to get dead on the money odd size short tenons. It's similar to the method where you drive a slightly oversize dowel through a hole. We have the wood in a chuck and turn a tenon slightly oversize The. He used a metal drill so ing jig and forced k the proper hole over that tenon making it the correct size. You could of course drill a hole in a pice of scrap steel to do the same thing
Open end wrenches work too
But the result is an end-grained plug which may be difficult to level. I need to try it and see.
Re: Open end wrenches work too
John Veerkamp
depending on the wood you could cut your blank side grain and turn it the same way. You'll probably need to start with shorter blanks . Will need really light cuts.
Re: hole filling plug question *LINK*
John McGaw
Are you willing to spend actual money? There are smaller plug cutters around although they aren't want I'd call cheap unless they will see regular use. I had though that Fuller made some some smaller ones but I couldn't locate them immediately but the link shows one smaller size that is readily available.
3/16" plug cutter
Joe in a Cleveland suburb
I don't know the answer to your question, but I am anxious to see build pictures of this project. Hope you intend to show us the build as you progress.
My wife and daughter have been asking for me to make them jewelry boxes that look similar to spice boxes for a long time. It was actually brought up this past weekend.
Leather drive punches will do it,
Keith Newton
But you may need to tweak them a little bit, by grinding to a little sharper angle. You can do that while spinning in the drill, and may get a little tooth by pointing it into the rotation.
You can find them at Tandy Leather, and probably many good local hardware stores, and HF for a cheap set.
William Duffield
As an example, start with this search. The first three screw extractors will do the job:
http://www.woodcraft.com/search2/search.aspx?query=screw%20extractors
If you need other sizes, or just want to make your own, you can make them from brass tubing, available from RC hobby stores in lots of different sizes and thicknesses. What is important is that you cut teeth in them using a saw sharpening file. The other important detail is that the tubing sizes are graduated such that the next smaller tube fits very closely in the larger tube. By selecting the right size tubes, you can cut plugs and holes to the same diameter. Of course, steel tubing also works, and stays sharp longer, but for delicate work like this and enough berries to decorate a couple of spice boxes, brass is good enough. A set of Lee Valley brad point bits will also get the hole diameters you need, very cleanly cut, and you don't need to clear the bottom of the hole, but they are a lot more expensive.
It looks like something was lost in John Lucas description of Michael Mocho's technique. It looks like he was typing on a cell phone. What you use to cut the holes (which doesn't work well in face grain) is a hardened drill gauge. (new, cheap grauges work too, but they don't last as long.) Old ones are very inexpensive, even Starretts. You use your empty tail stock as a ram to drive it over the end of the oversize plug. Remove the live center. Bring the tail stock up close to the end of the plug stock, turn on the lathe, slide the drill gauge between the tail stock and the plug centering the desired size hold over the plug, and crank the tail stock in. Back it off, slide off the index, and cut off the plug. You can choose any diameter you want depending on the assortment of drill gauges you have: fractions of an inch in 64ths, number sizes, letter sizes, or metric. Note that the gauge has one face with sharp edges and one face with rounded over edges. You cut with the sharp face, of course.
Phil Smith
Brass and stainless tubing is available in vast range of ID. Find tubing of desired ID and file teeth to make plug cutter of desired size. Pretty sure we saw example in Steve Latta's class.
Why not try....
.... taking the bit out of one of your Fuller type countersink bits? Never done it but I don't know why it wouldn't work.
Question about hollow wood screw extractors,
If anyone has a set will you stick a drill bit in them and tell me what the internal diameter is?
The problem(?) with lathe made plugs
I have a metal lathe and I can make a dowel of any diameter. But the plug will be end grain. End grain appearance may not be a problem but I suspect leveling the 96 "berries" on two boxes could be tedious. End grain does not plane as well as flat grain and I suspect that getting the berries flat would be tedious. Indeed, the extra force of planing the end grain berries might even rip them out.
Problem may be solved
First, there was a flaw in my assumption. The berries for the Chester County chest of drawers I made were too big for the spice box. I thought I used 1/4" berries but in fact they were 5/16". Then I discovered that LV sells a 6 mm plug cutter. I have drawn a full scale rendition of the door decoration and 6 mm will work, but 7/32" would be better.
Several suggested cutting teeth in a tube. I suspect this home made tool works better on paper than in practice. Has anyone actually cut 100+ plugs with this approach? I am imagining the teeth I could file in a small tube would be small and cut very slowly.
Re: Problem may be solved
Keith Newton
Yes, I have tried it with stainless tubing, with hand filed teeth, but I didn't give the two teeth set, and as you suspect, it didn't work all that well, due to no exit port to extract the plug. Plus I was using very dense wood, so jamming was problem.
Here is a tip that I use, when using the normal plug cutter. After drilling a bunch of them in a solid board until the bevel starts the little rounded tip, I clear the dust, then burnish some masking tape onto that face, then bandsaw about 5 /16" back from the edge.
Before peeling away anything, I take a fine point marker to mark the grain direction, then peal away the skeleton wood between the plugs, but leave them attached to the tape. I then make a little pallet for glue, large enough to capture a piece of the masking tape under the thumb, but then have a blob of glue on it to roll them in. It is easier to pick them off the tape and roll them than out of a container in the right orientation, and after they are rolled in glue, it is hard to tell grain direction, so the line really helps get them right.
Bill, I know you are a traditionalist, but here is another trick that I came up with for quickly inlaying squares. It was so long ago, that I don't have digital photos of the project. First I ground an old nail-set into a square taper, which I drove into holes drilled with tapered countersink drills, to cut and compress the corners.
It is easy to make a bunch of square tapered plugs using a scrap block on the bandsaw, by just cutting a bunch of wedge cuts side by side, leaving a sharp point on the edge, then flipping it 90º and doing it again, which leaves the finished wedges on the block looking like the spiked end of a meat tenderizer on steroids. Rotated it again, to bandsaw off the finished squares.
You can change the size of these squares by varying the depth that you drill the hole, and dipping the sharp end of these wedges in glue before driving is quick and easy.
It is best to use a medium density or soft wood for the background, because the more dense woods like rosewood don't compress easily enough.
There is lots of room for creativity here by changing colors from white, yellow, pink, into medium reds, on to darker red, then into black, like lots of berries do
in Nature. Even doing them in stages after the first glue has dried, you can have them overlap, then before the final layer is done, and the background is sanded, and maybe sealed, some could be carved leaving them proud of the surface for a 3D look.
geat tip
When I sawed the plugs they went everywhere as well as jamming the blade. And the grain orientation problem was just as you describe. I will employ the tape and marking. thanks
Re: Question about hollow wood screw extractors,
The set of three of these that I have, the smaller ones are each a slip fit inside the next larger one. Sizes are as follows:
o.d. 3/8", i.d. 5/16"
o.d. 5/16", i.d. 1/4"
o.d. 1/4", i.d. 3/16"
Re: The problem(?) with lathe made plugs
I didn't mean to imply that I use this technique for making berries. I agree with you, it is inappropriate. I wrote the post only to clarify John Lucas' description of the technique we both learned from Michael Mocho. I use it in spindle turning to precisely fit a round tenon into a drilled round mortise. For that purpose, it works very well, but it is helpful to pre-turn the shoulder of the tenon, because the drill gauge tends to push the fibers ahead of it and jam them up against the shoulder without cutting them off.
Ding ding ding.. that works.
Keith Newton
I just found an old dull drill bit which I broke off in a vice with a hammer, to put back in the top for the chuck to hold. It had some runout issues, but still did the job.
I did however need to sharpen the countersink though. Those tiny points were quite dull, but it was easy to do on my diamond wheel, which is saucer shaped, with the diamond on the side.
This was about 5/32", and my wood was Pear, which is very even texture, medium density.
