Fixed my Lufkin folding rule......
I posted a couple of weeks ago about the possibility of taking two broken rules and making one good one out of them. I did it. It was actually much easier than I expected. I used a beater wood chisel to pry open the brass flanges/hinge. Put the two parts together and clamped them in my vice. Used the same chisel to fold the flanges back down. The only tricky part to this was you have to look at the hinge and realize the two sides are different. The hinge pin is a rivet with one side the head and the other larger side the washer that holds the wooden rule part in on that side. Take out the part with smaller head. The head of the rivet does not hold the wood.
I actually put together two different styles of rules (one has red numbers at 16" intervals and the other does not) and it worked fine.
It tickles my pack rat gene to take tow broken useless things and make one good one out of it.
