OT Cleaning Pizza stone Question
I have a pizza stone that has gotten dirty. Some baked on crud on it. What is the best way to clean it? Burn it off? Soak it?? Scrape it?
Re: OT Cleaning Pizza stone Question
John Veerkamp
Scrape it best you can. DO NOT under any circumstances put soap on it>(DAMHIKT) As long as it is not too crusted it will work just fine. My older "dirtier" makes better than my new one.
Richard McComas
http://www.wikihow.com/Clean-a-Pizza-Stone
Chuck Bjorgen
I try to clean mine after each use by scraping with a metal spatula under running water in the sink. Funny but I get the feeling that the spatula comes through the process with a pretty sharp edge. I will also use a stainless scouring pad to clean off tough stuff. As someone else said, no soap.
Why?
How do you think they clean the bottom of pizza ovens? Do you return your cast iron cookware to shiny after frying? Of course the answers to these questions is that the black, mostly carbon, adherent crust that accumulates when oily stuff is cooked at high temperature does not have to be removed, and indeed, should not be removed.
If you are cooking the pizza as it should be, namely as high as your oven will go, whatever sticks to the stone will turn to largely carbon. And, just like for a well seasoned cast iron frying pan, this layer has no adverse effect on cooking.
Pizza cooking theory- The heat from the high temperature tile should render the bottom of the crust medium brown at the same time the cheese on top begins to bubble and form a crust. This ideal case is achieved by learning how high up in the oven to put the tile. Higher makes the cheese cook faster. I set my oven for 550 F and let the oven and tiles heat and equilibrate for 45-60 min before adding the pizza. Cooking time is about 7 min. I make the pizza on a cookie sheet covered by some high quality "parchment paper". The good stuff doesn't burn. The parchment paper makes the pizza slide easily and reliably onto the hot tiles. I sometimes yank the parchment paper out after about 5-6 min when I check the crust color.
Funny story- I cook on un-glazed quarry tiles. They are easy to store and cheap. I have cracked some over the years (some are 20+ years old and never cleaned) and thought I should get some backup replacements. I took one to a large tile wholesaler and asked if they had anything like the example tile. My tile was scrutinized and I was told that they had quarry tile , but not in that color (mostly black from pyrolyzed olive oill). I explained that the tile had been red but it was now black for use in an unconventional application.
Re: Why?
I had developed a bunch of "crusties" on the tile. The pizza was sticking to them and making it difficult to get the pizza off the stone and out of the oven. I just scrapped them off and made the surface nice and smooth again. A couple of passes through the Perfomax did a nice job. (just kidding) I was turning the leading edge of my peel snaggled toothed.
Part of my question was whether to clean it at all.
I like the idea of burning it off in a self cleaning oven, but I don't have one.
I cleaned the glass in the oven door. The oven is now on at 550 degrees with the stone in it. Burning off whatever it will.
The peel is a great thing. I may also try the parchment.
Re: Why?
TomD
what bout just burning it off with a blow torch as far as cleaning is concerned.
Re: Why?
I thought about that too, but was concerned about uneven heating and thermal stress/shock cracking the stone. I don't know why I an so concerned, I think these things are only a few bucks.
Re: Why?
TomD
The stones are only a few bucks? Gee, my wife agonized over buying her's, though that could have something to do with my having spent all the money on tools already.
Re: Why?
Ron Pemberton
So Tom, turn something for her or make something she can use and the concern for tool expenses will go away. Works for me
