small batch wood kiln
Dick Coers
I have quite a bit of air dried hardwood that was cut and air dried 15-20 years ago. It's time to do a final dry and kill any bugs. I intend to build an insulated room in my garage. I have a ceiling mounted natural gas heater in the garage, and would prefer to use it for the heat source. But I'm a bit stumped how I would circulate air from that heater, plus how to loop the air from the kiln box and back. I've researched dehumidifier kilns and I like the idea of a closed system, but not the energy cost of going to 135 degrees with electricity. I'll do some testing to see what the moisture level is, but also wonder if I will even need a dehumidifier. I also wonder if there are electric heaters that survive in that hot of room. Anyone done something like this? Any sources for a heater? Thanks so much for any help.
Re: small batch wood kiln
Hey Dick I posted this earlier this year, *LINK*
Keith Newton
per Ellis request for how to kill insects, but I also use it to finish drying AD wood.
It is so easy and cheap, plus easy and compact to store when not in use. If you do it mainly in Winter, the escaped heat can go toward heating your shop.
I'm in the process of building myself a nice Solar kiln, thinking about energy savings, but I'll have over $1000 in it before I'm done. I wonder how long I could run a little space heater for that much $?
Oh, I'm sure there will be some who would be concerned about a fire hazard with something close to the heater. I try to keep back a couple of feet from the front of the heater. However late this Winter, we were running so low on propane at the cabin, that I took a couple of these little heaters down since the gas price was around $3.50 per gallon. We bought 200 gallons at $2.14 this week, which saved $270 by waiting for the lower price of Summer. But while I was using this little heater, Sassafras my golden retriever would get right up to within 6" of it and go to sleep. I'd get up to go pee in the night, and drag her away, but she'd be right back on it before I knew it. It only curled the ends of her little eye-brow whiskers, so I'm not going to worry about it anymore.
I don't know how high electricity is where you are, but the heater was only maybe $50, and I've dried a stack of W Pine in about 1 week, which is about as fast as finishing oak down from 12%.
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=newarticles&file=articles_946.shtml
Thanks Keith, completely forgot about that article
cheap kiln
This works well for finishing off drying.
Build the pile out doors somewhere. Put crude frame around the pile. Sheet this frame with insulation board. Rent or borrow a large fuel oil fired heater like the contractors use in the winter. ( Or use two smaller ones on opposite corners; I have done it both ways depending on availability) They have a heater and blower. Stick it in one corner with air flow down a side of the pile. Put a window fan or two elsewhere to aid circulation. Run by day and rest by night. If the lumber is already thoroughly air dried you will be down in the 5-7% range in 2-3 days of drying.
I would dry 2-3,000 bdft lots of easily dried lumber this way in the summer. Never tried it on oak for fear of too rapid drying for oak. For poplar one can safely remove 15% moisture a day so no fear of too rapid drying of poplar. Cherry walnut also easily dried.
Worrying about the magic 130 degrees to kill bug eggs seems like closing barn door after horse is out. If the bugs have visited the damage is done and they have left. If the bugs have not arrived then the treatment does nothing useful.
