I reported here a while back that I had installed the Rolair JC10 air compressor in my shop, mainly because it is very quiet (60 dBA), and the old P-C had been scaring the dickens out of my dog, and startled me too sometimes. I am still pleased with the Rolair. I got a Woodcraft sales flier in the mail today, and they have it on sale in September for $210, which is $30 off the price I paid from Amazon.
Woodcraft #856904
You will not see the sale price at the link until September 1.
Full disclosure: I used to work for a Woodcraft franchise, but I'm now just a customer.
Wondering what you use this for. At less than 2-1/2 cfm at 90 psi it doesn't seem like you'll get much done aside from a brad nailer or blowing dust off the bench.
I run a pin nailer and a stapler (for upholstery and screens) and a finish nailer as well. There are a lot more things around the shop that need dust (and spider webs) blown off than just the bench. Some of therm are much more critical functions, like blowing dust off of projects after sanding or rubbing out between finish coats, and blowing chips out of the corners between tables and fences. It is useful for cleaning shavings out of deep turnings (i.e., hollow forms). Also, I use it for inflating tires on tractors and other equipment. I don't know if it would run a framing nailer, but I'm sure it would not keep up with a crew of carpenters or roofers, but I don't do that kind of work. It's only marginally useful for a die grinder, just in short bursts, but it's still faster than rasps and files. It can't keep up with a random orbital sander, either. I find it does everything I used to use the PC 2002 compressor to do.
There are other shop functions I think it would work for, but I don't use it for these: With a venturi, it will supply enough vacuum for a lathe vacuum chuck, or for a veneering vacuum bag, or even vacuum clamps.
And of course, it will blow up volley balls; blow up basket balls.
Glad to hear you are happy with it. There is no reason that you couldn't put another tank somewhere Tee'd off the line for longer burst. It would take longer to pump back up, but lots of projects are done in intermittent burst anyway. And since it is so quiet, it wouldn't matter to me that it ran longer, compared to listening to some of those loud ones.
Mark, Regarding framing nailers, I read some on-line reviews of this compressor, and one guy reported that his could drive five 3-1/2" framing nails before it needed to cycle. He didn't say which gun he was using, and I assume there are some differences between guns. I think it would keep up with an old geezer like me.
Thanks for the idea, Keith. I think I was on the verge of figuring that out for myself, but the advise always helps. Well, I guess I'll need to learn how to do some simple compressed air pipe fitting, and get to my nearest Harbor Freight while they have air tanks on sale. This would have been a bit easier on the old PC, which had two quick disconnect fittings, but the Rolair only has one.
Not that I'm po-poing your machine; I'm interested in a quiet unit.
My main air is in my garage so all I hear in the shop is that distant rumble when the big Ingersol kicks in to give me 12+ scfm. I use air for HVLP spray finishing, high speed carvers, and car maintenance (air rachets, lug gun) so 2.5 CFM holds no allure for me, except a quiet compressor for use outside the shop has real merit. I have a 2hp oil-less that will run 2 full-bore framers, but you have to check your fillings before you plug that sucker in. As my framing days are (hopefully) over, having a portable for trim work in the kids' homes would be a plus. I am, however, looking for something quiet in the 5 SCFM range that will allow me to do more than tack up moldings. Not looking to run a Dynabride, mind you, but more than a "duster."
When you get the portable air tank, it has a tire stem fitting for airing it up, but that takes forever, so get two male quick fittings, one male thread and one female, then screw them together. This allows you to plug the end of your airline straight into the tank from any hose, then open the valve, hands free.
Also HF makes a nifty 3way splitter That I added to a couple of my compressors. It is much cleaner than the old T or + pipe fittings that I used to put together.
I normally buy 50' hoses, but cut them into 20' and 30' lengths for around the shop, so there is less to trip on. If you get the tank and 3 way, you can use any airline out of the splitter to the tank, or cut one dedicated to wherever you want to store the tank, and it will always be ready to go when you need to take it out for emergencies. Back when all my guns were Senco, that tank was good for over 100 shots with 18 ga stapler or pins, but I'm not sure with what I have now.
William, Whatever you do, do not use plastic pipe and fittings for the system. Compressed air has a lot of stored energy and if the pipes burst you could have shards of plastic flying around. Might be unlikely, but you don't want to be there when it does.
I was going to run piping in my shop, but the shop is so small it does not matter.
Thank you for the warning, Barry. I think I had read of that danger somewhere.
My shop is also small enough that dragging Flexeel hose around is sufficient. If I needed to put the compressor up in the loft, to keep it quiet, then I'd start thinking about iron or bras pipe.
I'm going to have to think about the male and female quick fittings. I have some spare fittings that might be helpful. It sounds like the three way connector, of which I had no clue, is going to make this a lot easier.
If I want to cut a few feet off the end of a hose to make the connection between the compressor and the auxiliary tank, what do I need to know? Obviously, I'd like to be able to quickly disconnect them, so I can haul either the tank or the compressor to a job, depending on how much air I think I'm going to need.
The male and female were just the pipe thread end, of two male quick connects, because the tank and hose end will both be females. You can use two male NPT with a coupling between also. I keep mine tethered to the tank so it is always there, without having to look for it.
If you cut the hose, you will need a hose barb fitting to shove into the hose, with pipe thread on the other end, unless they have quick fittings already made up on a hose barb. You will need a hose clamp for each of those too.
HF offers some packets with lots of goodies like tire and nozzle with about 10 other fittings very cheap, that would be worth getting. And don't forget teflon tape for all the pipe fittings.
The short length of yellow hose came with the tank, including the female fitting on the end of it. The rest of it I added. I set it up so that it can be added to an air compressor (for added buffer capacity when spraying or using larger nailers) without using up a quick connect port, or so that the tank can be filled and taken somewhere to fill a tire or something like that.
Female quick disconnects close when disconnected, male quick disconnects don't, hence the small 1/4-turn valve on the T-assembly (that's also why the male end is always put on air tools--so they discharge when disconnected).
Wonder if the same company makes a bigger unit that is as quiet?
The idea of putting a larger tank in line would solve many of the problems for most of us. I tend to spray in short bursts. Spray a small piece and move it out of the spray area and bring in the next one. By the time I shuffle everything around, the compressor catches up. OTOH I think my current compressor has about 3.5 CFM.
That approach is good, up to a point. Pretty much all smaller compressors have a duty rating on them that is substantially less than 100%. Mine is 50%, and it's rated for 1 hour--that is, the compressor can run for 1/2 hour of every hour in general. If I can coat whatever I'm spraying in 1/2 or less, I'm good, though once I run through the stored capacity above the pressure at which I'm spraying, I may have to pause to let the tanks refill. In other words, if I'm spraying 5 cfm @ 40 PSI, and the compressor can only deliver 4 cfm @ 40 PSI, then once I am down to 40 PSI in the tanks (even with the compressor running), then I would have to pause to let the compressor catch up. Of course, it would be running continuously once the pressure in the tanks drops below the low pressure switch setting, if I kept spraying.
A 2.5 cfm (cubic feet per minute) compressor will have real trouble with an HVLP spray gun, but it will (with added reservoir tank) be enough to give reasonable atomization on a conventional spray gun in short jobs, depending on what finish you're spraying. Caution, however, must be paid to the "duty cycle" rating on the compressor as exceeding it will damage both the motor and the compressor pump. This is especially true with oil-less machines that run hotter. If you'll be spray finishing, play close attention to the limits on the compressor and the requirements of the gun you're using. Note as well that with the compressor running near its limits, the output air will be warmer and that may "play" with your finish film by speeding up the drying that can prevent the wet film from properly leveling.
Keep the old compressor that makes your ears bleed, and tie it into the line too, to combine the CFM. Then after the spraying is all done, unplug it from the system, and go back to the peace and tranquility of cutting wood.
Barry, you are correct if you are referring to the PVC / CPVC pipe used for water plumbing. However there is a multitude of plastic lines made exclusive for air lines, this material is quite safe and is used extensively in Industrial machine applications. Typically when you see robotic machinery that has air operated grippers ~ they are plumbed using plastic air lines. As an Engineer in a production environment, I used plastic quite a lot. We had several thousand feet of various sizes of line in use in many machines. The failure mode is normally a "split" and is normally encountered when a line is flexed repeatedly, sometimes up to 10,000+ times a shift! I don't know if there is any ridged plastic approved for air applications, but a lot of Flex line is approved for 150 PSI applications by OSHA.
