200+ woodworking book reviews
Stacked Dado set Recommendations
Looks like a new 8" dado set is in my near future. I haven't kept up with the latest reviews. Is Forrest still the way to go or is there a new top dog?
Thanks
Tom
Re: Stacked Dado set Recommendations
Jerry Roberts
Forrest is probally the best one can buy,BUT, Its a little pricy for me. I have the CMT with all the shims for many years and its worked great. I cant remember what it cost and it came with a chart as to what shim to use for what width. Very satisified.
Rick L
Re: Oshlun *LINK*
Rick L
Oshlun seems to be making quire a few new affordable items.
Oshlun Dado
Dale Lenz
Dale Lenz
Purchased an 8" Forrest over 10 years ago on the advice of Lee Grindinger, had the outside blades ground flat, no glue squeeze out channel, for a Flat bottom. Only dado set I've owned so cannot compare. But would buy from them again.
Same here
Gary Smyth
Forrest. No changes except return for sharpening twice in twenty-seven years. Always sent to Forrest. Bought mine at a woodworking show in DC. Even with show discount scared as hell to spend the money. Never been disappointed though. Not heavy use. Three maybe four projects a year. never a concern with use.
Ditto
Hank Knight
My experience with the Forrest Dado King is pretty much identical. Moderate use, 1 re sharpening in the last ten years. Completely satisfied.
William Duffield
How many dados do you cut? Is the material that you put into the dado always the same thickness? Do test cuts, swapping out spacers and shims, and making lots of test cuts frustrate you? These problems go away (and I think I get just as perfect cuts as I would with a Forrest) with my Freud SD608 Dial-a-Dado set.
http://www.woodcraft.com/Product/2020095/35773/Freud-SD606-Circular-Saw-Dial-Dado-Saw-Blade-Set-6-X-58-Bore.aspx?keyword=&refcode=10INGOPB&device=c&network=g&matchtype=&gclid=Cj0KEQjwjtGfBRCN4-LU9ODG1-wBEiQAy_Xp7_Wa3fIQ9GiZ9lQwn6456FXt4-ZDueBttsX2hdVBSZIaAl5g8P8HAQ
Note that Freud also makes a 6" set of these (SD606), which you will probably appreciate if you have a contractor saw with a 1-3/4 motor. A motor of this strength doesn't deliver enough torque to effectively drive a full stack of an 8" dado set. However, if you have a SawStop, or are contemplating upgrading to one (which I highly recommend) you should know that they don't make a brake that functions with a 6" dado, so you should get the SD608 instead. The same recommendation goes for any other manufacturer's dado stack.
Scott in Eastern Iowa
Heyy Tommy.....
What you dont like Freud ??
Hello William,
I cut a significant amount of dadoes....all widths and depths. I have a Unisaw, so power is sufficient. I had a dial type set many years ago but got a stack set and found it preferable.
Best,
T
Hey Scott,
I have a Freud currently. I have had it for many years...no major complaints. But it needs service....sharpening, broken teeth etc. So I will get it serviced. But I use dadoes so much that it would help to have 2 sets that I can rotate. So I figure if I get another set, I might as well see what other folks are recommending these days.
T.
Four things to consider
1. Do you want/need a flat bottomed cut? Some do and some don't.
2. Will you be cutting plywood? Some are ground to lessen fraying the face veneer but that leads to a pointy more fail tooth on the outside blades.
3. Will you need to set the width precisely to accommodate various thicknesses that will be inserted into the dado? Some are continuously variable while others require an assortment of shims to be on hand.
4. Will you be doing stopped dadoes? If so a 6" dado is better than an 8"
Number 3 is my most important criteria and to that end if I cared to afford another dado it would be one that had a continuously adjustable thickness function. I think Freud and maybe others offer this feature.
William Duffield
The Freu ddial-a-dado is a stack dado set, but the shims have been replaced by the dial mechanism. Was yours a wobble dado, perhaps? If so, I wholeheartedly agree with you. Any stack dado is vastly superior to one of those gizmos, but the Freud mechanism is also much more convenient than a set of shims. You need to select the right set of chippers, and assemble them like any stack set, but after you've made your first test cut, you only need to loosen the arbor nut and turn the dial the necessary number of graduations to finely adjust the width, and retighten the arbor nut. Removal of arbor nut, flange, and one blade is not necessary and you don't need to figure out with a calipers or a calculator which fragile shims to remove or add.
http://www.freudtools.com/index.php/products/product/SD608
Good Food for Thought
My work is mostly with hardwoods. But yes, occasional ply. Flat cuts are a must.
Thanks for that input!
T.
Tempting to Try
Yes, now that you mention it, the first set was a wobble set. Terrible. I was adjusting shims for cuts just yesterday. Definitely more time consumption. I appreciate the suggestion.
T.
Re: Tempting to Try
William Duffield
I couldn't recommend them to everybody, due to "sticker shock", but they can save significant if you are doing a lot of dados, especially in a production environment. And, if calculating small fractions is not your forté, you could waste less wood and at the end of the day decrease your stress level :) .
bud
I have the Freud Dial A Dado. After you put in the correct number of chippers you - turn off power to saw, loosen arbor, turn adjusting ring, (each click equals .004) tighten arbor nut. The dados are flat bottomed and straight sided.
Bud
Two Freuds, and like them both
Tim Greif - West of Chicago
Tom,
I've got two sets of Freud dados, a D208 and D308. I got the 308 for next to nothing or I probably would not have two. I bought the D208 primarily since I use it on my RAS as well as my contractor saw. The negative hook angle is great for the RAS as it reduces the climb tentency and feels a bit safer. It's a 12 tooth blade.
The D308 calls itself a safety dado, probably due to the anti kickback design of the protrusions behind the carbide cutters. But it's a positive hook design and 24 teeth, so it can be a bit scary using it on a RAS. I use it primarily on the contractor saw.
Both blades cut clean, flat bottom dados. The D208 requires a bit more feed force used on the table saw compared to the D308, likely due to the negative hook angle. I prefer the cut of the D308 on the table saw. If I had to pick only one, it would be the D208 with the negative hook since I'm still stupid enough to regularly use my RAS.
Good luck.
Many years ago I had a wobble cutter. The thing had about ten long thin fingers. I had it on a RAS cutting dado's across pine shelving boards. There was a huge stove behind the RAS. It started to vibrate, so I turned it off. On of the teeth was missing. Never found it, never knew where it went. Did not see or hear it hit the stove. Scared me so bad I threw it away. That tooth was bigger than a .22 bullet.
