concave coutout
Jack Putnam
I am working on a fly reel display the reel is about 6 inches in diameter and I am trying to make the reel as real as possible ( pardon the pun) the problem I am having is the part that is on a fly reel that connects to the bottom of the rod is concave. I am using pine and birch plywood for the display. The piece of wood I am wanting to make concave is pine and is 4 inches long 5/8 inches wide and 6/16 of an inch thick.
I think maybe at this point the wood is too small to work with I should have made this piece when the wood was wider. I was thinking some small sanding drum connected to a dremel tool would do the trick but the small sanding drum (same size as they file dogs toenails) is a little too big. So I am open to ideas I can't think of anything else that would work. Again I think I should have done this with a bigger piece of wood before I cut it done to size. Thanks for any help you can give.
