OT wall to wall carpeting over Pergo
Howard
I want to put wall to wall carpeting in a room that has Pergo on the floor. The carpeting company insists that the Pergo has to come up.
If they install the tackless with long enough nails to go thru the Pergo what is the problem installing over Pergo?
Thanks
Howard
Re: OT wall to wall carpeting over Pergo
Howard, I am not an expert, but my understanding is that Pergo floats. It is not attached around the edges and there is supposed to be a space around it to allow it to expand and contract with changes in moisture content and temperature. If you "fix" the perimeter by driving nails through it for the tackless strips when it tries to contract it will pull the seams apart and when it tries to expand it may buckle.
I have seen some that was very poorly installed in some of the houses I have bought to flip. Lots of cheap worn out shabby laminate out there. We are fond of saying that cheap laminate causes foreclosure.
It comes up a lot faster than it goes down. You might even be able to sell it on Craigslist.
paul in AZ
Be aware that unless they have changed it Pergo delaminates and swells with prolonged exposure to moisture .
Under carpeting this could be a problem if there was any kind of water spill.
Pergo is less likely to be glued down. A floating floor should be a messy but easy removal.
Dick Coers
Yup, remove it. It will take longer to carry it out than take it up.
Jason Roehl in Lafayette, IN
I sure wouldn't want to have to install tack strip by nailing it through the laminate, considering what it does to carbide saw blades. That top layer is pretty tough, and I don't know if there is tack strip made with nails long enough to go through it.
Nailing tack strip directly to the Pergo, without going through it, will almost certainly cause the Pergo to buckle when the carpet is stretched.
Jason
Jerry Roberts
Listen to the carpet people. I just put Pergo down in 2 bedrooms and wouldn't consider putting carpet down over that paper floor. The least moisture hitting it turns it into a pretzel im told.
Howard
Thanks for all the advice
When the carpet installers went to remove the "Pergo" they found that it was glued down so they installed the carpeting on top of it.
Howard
