Spray paint blush
Spray paint blush
Spray paint blush
Gary smyth
Duplicolor aerosol spray paint, metallic. Sprayed in 77 degree heat, shade, and 56% humidity according to the weather info station (about 10 miles away). Spraying 6" x 1/2" thick cut out sign letters. Final top coat. Sprayed as in the past but this time got heavy blush. I couldn't believe it as I checked, and followed the proper ranges for the product. As soon as I could I placed the letters in a air conditioned room to see if I could lower the humidity and see if it might come back. Too dry and too late
Now what to do? The letters should be glossy. Do I wait a week for paint to be fully cured and respray or sand lightly and respray, would buffing help? Final coat too. Sides of letters feel powdery which indicates to me the paint flashed almost out of the can. No matter what I'm pushed back a week so I have time to fix, but how.
Re: Spray paint blush
Re: Spray paint blush *LINK*
Dick Coers
Did the letters come out of the air conditioning right before the spraying? Somehow, the moisture in the air condensed on the letters. You can often spray lighter coats and get away with poorer conditions than when you spray a heavy coat. To repair lacquer, you can often hit it with a couple coats of just slow thinner with no product in it. Mohawk makes a blush remover, but I would call the maker of your paint to check with them first.
Mohawk
