What would you use for exterior wood filler?
I'm trying to patch up some exterior railings made of redwood. There are some minor defects like nail holes in them that would look better if they were filled. The rails will be painted.
What would you use?
Re: What would you use for exterior wood filler?
BilWil
I would use epoxy or bondo.
Jason Roehl in Lafayette, IN
Epoxy and bondo aren't great exterior choices, IMHO.
Lightweight spackle, glazier's putty, Crawford's putty (orange can) or spackle (green can), Durham's Water Putty (powder mix).
My go-to is lightweight spackle. I've filled probably hundreds of thousands of exterior nail holes with it. The only downside is if it gets rained on before getting painted, some may wash out of the hole. You can put on a little extra and sand flush after about 15-30 minutes, or apply it flush with a putty knife (or even your finger) if you're skilled. It will flash with anything other than flat paint unless you put a second coat over it.
Jason, painter by day
Thanks, light weight spackle it is...
Our local Ace hardware store paint guy referred me to their vinyl spackle. I've used it for painted exterior wood for five or more years now, and have never had a problem.
It shrinks a little in drying. If you've got a big hole to fill, do most of the filling with something else (wood patch, fixall), and then use the spackle for the final finish coat. Sands out beautifully.
I would use
Lee Schierer in McKean, PA
Minwax High performance wood filler. I used it to repair some trim on my old front door. It out lasted the wood I put it in. Yet it works easily with wood working tools and can be sanded smooth. Paint sticks great.
Mix as much or as little as you need. It sets up fast, so don't mix too much at a time.
Lee
Pretty sure that is "bondo"
Dick Coers
with maybe wood flour as a filler.
