Framing Nailer questions
As some of you know many of my tools were stolen about a year ago. One thing that disappeared was my ancient Senco framing nailer. (SN4 Maybe?) I bought it when there were few choices. Framing nailer or Not.
I have some clipped head nails left for the old gun, but my understanding is th code strongly frowns on them and wants full round head nails.
What would you buy to replace it? I don't really need one, but I feel a little naked without it. Sometimes you have to pull out the big guns.
Re: Framing Nailer questions
Re: Framing Nailer questions *LINK*
Keith Newton
I have not had this one long, but I think it got high ratings. My last one before it was a PC, which was pretty good, but when it broke down, I really need one that day, and it seems like this one could use the same nails.
The one before that was a Duofast clipped head, which I used for a long time, but fixing it was too costly for as old as it was / fixing it again cost.
http://bigskytool.com/Hitachi_NR90AF_Framing_Nailer_Offset_Round_Head_Wire_Weld_Collation_(Grade_C_Reconditioned)___i1666.aspx?source=Froogle&gclid=CPuIkIPak8ACFeRj7AodlgcAPg
Someone else mentioned Hitachi to me.
Do you like the wire collated nails? Do they leave debris behind? A pro on a framing crew pointed out that its not good to have a bunch of trash left over when the job is over.
and are the nails expensive? And commonly available?
Does it do a relatively pretty job? Like for nailing a deck where the work would be left exposed?
Keith Newton
Got it at Home Depot, and they have the nails. You can look it over there and compare it to probably 4 other brands. I think it shoots as good as any I've ever had my hands on.
Probably shouldn't tell this on myself, but the first day on the job, we started putting up rafters. I was up on a ladder holding the first gable rafters to the ridge, and must have had the gun hanging on something too low to reach, so lifted it by the hose. Only having one hand to work with, I tried to prop it on something while quickly moving my hand from hose to handle, when somehow it moved, hit the quick release on the hose end, then fell about 28' to the ground.
I can't repeat the words I said while it was on the way down, but it wasn't nice, and I was not happy with myself. But the good news is that it didn't damage anything about it, so I guess it must be pretty tough.
TomD
I have a Bostich one that shoots clipped nails. They are still widely sold. According to the Senco Q&A the prejudice against clipped heads is not scientific, but local inspectors in earthquake and hurricane zones may be prejudiced, so why fight local preferences. If you were following local preferences when you originally got your gun, you should be good to go again.
Barry,
I have used a Pasload 350 for years and am well pleased. It is, however, a clipped-head nailer so it can't be used where local codes (rather than just the inspector) require full-head nails.
BTW: Since you mentioned decking, I would never use a framing nailer to put down decking. All my decking is screwed down to make repairs and replacements far easier.
Ditto.  Hitachi.
Grant in Iowa
We have used the Porter cable, which is a nice tool and is free of trouble, and the Hitachi's. Given a choice, the Hitachi's are the chosen tool mostly due to weight, balance, and function.
We also like the Hitachi roofing nailers.
FWIW,
Grant in Iowa
PS
Framers in my area will most always go to Hitachi guns when working with LVL, microlams, and any other engineered materials on account of the driving power factor of the Hitachi framing guns.
Dave Bair
If you don't really need one, give Harbor Freight a try. It may not frame an entire house, but it'll do the occasional job with no problems. Their nails are really inexpensive, too.
I screw decking down also....
What made me think of this was a friend was rebuilding a deck and using 2 X 6's for deck boards because the framing was on two foot centers. I have a Senco Duraspin. A Drill that uses strips of screws. A wonderful tool. It will only drive two inch screws though, so they are not long enough for 2" thick decking.
(If you get a Duraspin, take a lesson from my son. He managed to get it in reverse. Surprisingly, you can drive a screw with the drill in reverse if you put your entire weight on it. Of course, you can pull it out with your fingers.)
I would have let my friend use the Duraspin if it would have done the job.
He rented a framing nailer. I would have loaned him mine, if it had not been stolen.
Great
for rocking a ceiling.
TomD
I bought the Canadian equivalent of an HF roofer. It has been nice. Early in our relationship I pulled on the connector and shot the gun off the roof where it landed on a concrete walk 2 stories + roof below. I did that more than once before tying the gun to the hose. No damage to the gun, even though the nail bin is partly clear plastic. So I am impressed so far. Of course for me roofing is not a profession, I only need it to roof my buildings, or I would have bought something better.
