Have a question? Ask Woody!
Finishing insides of cabinets
Larry
Hi,
I plan on finishing the Inside of some cabinets with Clear Lacquer, the outside will be Acrylic Latex paint. Will finish the inside first.
Will there be any problem If I get any Lacquer on the outside?
Thanks
Re: Finishing insides of cabinets
Dick Coers
What will you be using for primer under the latex?
Larry
Oil base kilz ?
Jerry Gibbs
curious why you need oil base under acrylic?
Lee Schierer in McKean, PA
I just made a cabinet for my daughter that had areas that were finished with polyurethane that were adjacent to areas that were to be painted. I masked the areas where paint was to be applied with painters tape. Once the poly was finished, I waited a day and then removed the masking on the area to be painted and applied tape over the poly areas that were adjacent to paint. It worked quite well.
As a primer, you could try BIN Primer with shellac and then apply your latex paint over that. You can even tint the BIN primer.
Lee
Larry
I like the way oil base sprays
Larry
I have alway like Kilz. How does BIN Primer spray?
Kilz versus BIN
David Yoho
I can't answer your question about how BIN sprays because I've never sprayed it before. However, I've sprayed shellac before without problem and would suspect the BIN would too, even with the white pigment it contains.
Without trying to start a war with Kilz users, I've always been curious as to why folks choose it over the Zinsser BIN when trying to block a stain or they need a primer coat before paint. It's always been my understanding that shellac is superior at blocking stains and odors that are present on a surface. Like all Zinsser products, BIN contains shellac that has a white pigment added.
I recently was talking to a friend that said he had been using Kilz to try and block pine knots from bleeding back through the paint on some exterior porch posts without success. I told him I'd used BIN on mine and never had an issue with the knots other than sap oozing.
Like I said, I'm curious, and wonder if there's specific reasons for choosing Kilz over BIN.
Re: Kilz versus BIN
As for the cabinet, I would use Sealcoat Shellac on the inside. It drys quickly and if you get dome on the exterior you can paint over it. It has no odor once dry.
Recently I bought a house where people had left dogs pinned yup inside it for a long time. They had peed everywhere. They floor was saturated in places, the metal corner beads had rusted away and the ducts were ruined. On the advice of a paint company Rep. I coated the OSB floors with Bin. His company did not make it, but he thought it had superior odor blocking properties. It worked for about a day. Fairly soon, the worst spots started coming back through. Within 72 hours it became clear it was not working. We had gone over the bare floor with a carpet machine two times with urine destroyer and twice more with just soap and water.
We ended up removing 11 sheets of plywood (T&G and glued down, a bear of a job) and replaced them. Then painted the entire floor with Oil based Kilz. Also replaced the ducts, corner beads and drywall up 16". That worked.
I think the Bin failed because there was enough ammonia in the pee to destroy it. None of this has any bearing on the cabinet question but does illuminate one scenario where Bin/Shellac is not superior.
Valid point
David Yoho
Certainly ammonia would be a problem for any shellac or shellac based product. Good point, Barry.
Dick Coers
I asked the primer to see how heavy bodied it would be. I was concerned that if the primer was a little light, you may get a different look where the lacquer may be on the outside. You know, more grain fill. Sorry it took the post way off base. I think I would still be cautious about too heavy of a coat of lacquer on the outside.
Howard Acheson
I'm confused. You said you are using lacquer (I assume you mean solvent lacquer) and waterborne acrylic. Neither of the two are "oil based> What is the "oil based"?
Kilz versus BIN
Most likely either product would have failed trying to seal in the odor. Replacing the plywood and damaged drywall is what cured the problem, the stain blocker was only window dressing and probably wasn't needed.
Lee
Re: Kilz versus BIN
I suspect you are right. I knew the situation was horrible, but tried everything I could think of to avoid tearing out the plywood. I have seen many pee stains on hardwood and carpet And if they are minor and sparse, they don't present much problem. In this case the carpet had been pulled from one room when I bought the house. Unfortunately the plywood was glued done, and glued down well. We ended up cutting it to pieces and tearing tearing it off each joist individually. Then used a Multi-tool with a scraper blade to clean the remainder of the glue off the joists.
The carpet we pulled out was still slimy even thought no one had lived in the house and the dogs had been gone for six months. Even after all we did to clean the plywood, when we threw it out into the yard and the sun hit it, it oozed crud. Truly nasty. I learned a lot from this and if I see it again, I will not buy the house or factor it into my bid and will pull the plywood immediately.
One unexpected expense was we ran one sheet short on plywood and I side stepped into the hole in the second floor and landed on a joist, breaking a rib. Went to the Doc in a Box and they charged me $600 to tell me I had a broken rib and that they couldn't do anything for it. Next time I will try to have a sheet left over rather than be one short. And I will see to it my son covers the hole when I tell him to. I am not sure the rib will ever heal. Its been about two years.
