Mixing lac.finish
Frank /Fenton Mo.
I have 1/2 a gal. of a 40 sheen precat. and a 1/2 gal. of a 10 sheen precat.
Both the same maker can I mix those together ?
I have done that before with reg lacquer.
Thanks
Frank
aka mantelguy
Mixing lac.finish
Frank /Fenton Mo.
Thanks
Frank
aka mantelguy
Re: Mixing lac.finish
Clint Searl
If you have the time, let them settle out for a week, then decant and mix the clear stuff from both. Add the dregs (flatting agent) in the amount to get the desired sheen.
Howard Acheson
Give the formulator a call. Most have a tech department and they would know best about their products. That's the best way to get the right answer.
Frank /Fenton Mo.
Mixing them together worked without a problem.Just sprayed the 3rd coat.Thanks for the replies .
